Haversine formula
Posted: Tue Nov 11, 2025 5:16 am
by viktor_au
Wonder if anybody work with the gps distance calculation.
Any suggestions how to implement the Haversine formula?
Thanks.
Re: Haversine formula
Posted: Tue Nov 11, 2025 9:14 am
by chipfryer27
Hi Viktor
Whilst not actually doing it myself I did earmark this site as it gave many different ways to calculate, and also mentions a TRS-80 being used to calculate (my second computer)
https://www.movable-type.co.uk/scripts/latlong.html
Might be of some interest.
I found a lot of sites "scary" with their equations, but it isn't too difficult really and the above site also has some excel formulas.
Posted: Tue Nov 11, 2025 10:58 am
Hi Victor.
This is what I found:
Haversine Formula - Simple Explanation
The Haversine formula calculates the distance between two points on Earth using their latitude and longitude coordinates. It accounts for Earth being a sphere (roughly), not flat.
What it does: Given two GPS coordinates (lat1, lon1) and (lat2, lon2), it tells you the straight-line distance across Earth's surface.
The Formula Simplified
The formula works in steps:
Calculate the differences in latitude and longitude
Apply sine functions to account for Earth's curvature
Use Earth's radius (6371 km) to convert to actual distance
Implementation in Flowcode
Here's how to break it down into Flowcode calculation icons:
Step 1: Convert degrees to radians
lat1_rad = lat1 × π / 180
lon1_rad = lon1 × π / 180
lat2_rad = lat2 × π / 180
lon2_rad = lon2 × π / 180
Step 2: Calculate differences
dlat = lat2_rad - lat1_rad
dlon = lon2_rad - lon1_rad
Step 3: Haversine calculation
a = sin(dlat/2)² + cos(lat1_rad) × cos(lat2_rad) × sin(dlon/2)²
c = 2 × atan2(√a, √(1-a))
distance = 6371 × c // Result in kilometers
In Flowcode Calculation Icons:
Use separate calculation icons for each step
Store intermediate results in float variables
Use the built-in sin(), cos(), sqrt() and atan() functions
You can then use the link that chipfryer27 posted for testing the formula works.
If will be best if you use floats for the constants, e.g. instead of 2 use 2.0
Posted: Tue Nov 11, 2025 6:12 pm
by viktor_au
Thank you guys for the help.
Will try to implement.
I thought I have to find the difference between the (for example) lat2-lat1 before the radian conversion.
