Please Add PIC16F152xx (PIC15276....)
Posted: Mon Mar 09, 2026 8:19 am
by S_VE
Greetings,
Please add PIC16F152xx (PIC16F15213, PIC16F15214, PIC16F15223, PIC16F15224......)
this is bit urgent requirement, kindly help at the earliest.
[ this should be very easy for you, as PIC16F15276 is the strip down version of PIC16F15376 ]
S_Ve
Re: Please Add PIC16F152xx (PIC15276....)
Posted: Mon Mar 09, 2026 5:05 pm
by BenR
Thanks for the suggestion, I'll get them on the list and see if we can get these in ASAP for you.
As you say hopefully not too much work though you may have to use your own version of the XC8 compiler if they are not supported in the standard Flowcode toolchain compiler.
See here for details on how to do this.
https://www.flowcode.co.uk/wiki/index.p ... ion_of_XC8
Posted: Mon Mar 09, 2026 6:27 pm
by S_VE
Thank you Ben,
I understand about XC8 compiler requirement.
I have just checked about this in Microchip website, for both PIC16F15276 and PIC16F15376, the Minimum Version required is XC8 V2.05.
Posted: Tue Mar 10, 2026 8:43 pm
by BenR
These chips have now been added for you and should be live now in the v11 library updates.
I've tried to be fairly thorough with the definitions but I haven't done much testing on them so please let us know if you find anything that either doesn't compile or isn't working as it should on the hardware.
Posted: Thu Mar 12, 2026 10:05 am
by S_VE
Thank you so much Ben,
I will test on hardware and get back to you if required.
Thanks once again for your quick action.
