Modbus TCP read error
Posted: Wed Apr 15, 2026 4:22 am
by seokgi
I want to aggregate multiple devices operating via Modbus RTU serial and transmit data using Modbus TCP.
MCU: PIC24FJ512GA606
LAN: W5500
When checking in Modbus POLL, it does not work at all and only repeats read error and write error. If I delete the listen (502) from network comm in the main directory, a message appears stating that the server has closed it.
Please help.
Re: Modbus TCP read error
Posted: Tue Apr 21, 2026 8:17 pm
by BenR
Sorry for the delay in getting back to you.
The NetworkComms1::Listen component macro call in main is not required.
I'll see if I can replicate the problem with the server socket being closed as this shouldn't be happening.
You could try changing the Modbus TCP component property "Open and Close Socket" to No and see if that helps.
Posted: Thu Apr 23, 2026 1:09 am
by seokgi
Do not support this option.
Thank you.
Posted: Thu Apr 23, 2026 4:44 pm
by BenR
Here is the property I mean, If you don't have this maybe check the help -> library updates to see if there is a new version of the component.
Screenshot 2026-04-23 164335.png (53.58 KiB) Viewed 2606 times
Posted: Mon Apr 27, 2026 12:54 am
by seokgi
It works well. However, errors still occur about once every 20 times.
Thank you.
