Good afternoon. Could you tell me if FlowCode has a built-in speed parameter? I’d like to change it, but the only way I’ve found is to use the delay function, and that’s not ideal for complex programmes.
Kind regards
Zhmill1789
Stepper Motor with a A4988
Zhmil1789
- Has thanked: 9 times
- Has thanked: 160 times
- Been thanked: 949 times
Re: Stepper Motor with a A4988
This would probably be best as a new topic - but I'll not try moving it on phone...
What are you trying to achieve - what speed are you wanting to change? For app developer or for an MCU? Or do you want multiple 'tasks' to run at set intervals / rates?
If you post more details possibly with some sample code - then we can try to help.
- Has thanked: 286 times
- Been thanked: 450 times
- Has thanked: 613 times
- Been thanked: 806 times
Timer interrupt or timed event is good for things like a stepper motor where you want to step at a fixed or variiable rate without blocking the main program.
