Power (pow) returns incorrect result
Posted: Tue Jul 28, 2026 3:15 pm
by mnfisher
Just spent a while chasing a bug in my code - but it turns out 'pow' returns an incorrect value.
It actually returns the result - 1 (except for pow(2, 0) and pow(2, 1))
The attached demonstrates this behaviour (on an Arduino - other devices may differ?):
2**0 = 1
2**1 = 2
2**2 = 3
2**3 = 7
2**4 = 15
2**5 = 31
2**6 = 63
2**7 = 127
2**8 = 255 // The example in the WIKI should = 256!
Re: Power (pow) returns incorrect result
Posted: Tue Jul 28, 2026 3:32 pm
by mnfisher
It might be because it uses floating point...
pow(2, flt_fromi(FCL_I));
- not sure why it doesn't also do flt_fromi(2)?
However - it shouldn't make it so wrong ?
Wrote my own integer
Posted: Tue Jul 28, 2026 5:20 pm
by Steve-Matrix
Thanks, Martin.
I've just checked and confirmed this. But on an 8-bit PIC it's fine.
If I strip out the flt_* functions in C code, then there are some oddities:
FCV_F = pow(2, 4);   //this produces 16.00000
//but...
FCV_I = 4;
FCV_F = pow(2, FCV_I);   //this produces 15.999999
FCV_I = pow(2, FCV_I);   //this produces 15
(FCV_F is a float and FCV_I is an int).
So there is a truncation issue.
Perhaps the "pow" function in the Arduino is using some algorithm that makes the power calculation quicker, but introduces this truncation issue.
We'll continue to investigate.
Posted: Tue Jul 28, 2026 5:55 pm
by mnfisher
This might give a solution:
#include <math.h>
#include <stdio.h>
int main()
    int a, b;
    // Using typecasting for
    // integer result
    a = (int)(pow(5, 2) + 1e-9);
    b = round(pow(5,2));
    printf("%d \n%d", a, b);
    return 0;
Which looks to give the correct result on both cases (from stackoverflow)
Posted: Wed Jul 29, 2026 1:16 pm
by Steve-Matrix
More on this. It's not a bug as such. It's the way the pow() function works in the C code for Arduino/AVR.
The pow() function returns a float. And if a float is casted to an int then this is a truncation rather than a rounding. So 15.999999 becomes 15 and not 16.
So in your code it's probably wise to use the round() function if you are definitely expecting an integer rather than relying on C casting.
myInt = round( pow(2, x) )
