TCA9548A I2C expander for Arduino , ecc
Posted: Tue Jul 27, 2021 9:16 pm
by solozerouno
It's possible to ask for the addition of a component like an I2C i/o expander with 8+8 pins the TCA 9548A is perfect with Arduino UNO , etc.
thanks a lot.
Solozerouno.
Re: TCA9548A I2C expander for Arduino , ecc
Posted: Tue Jul 27, 2021 10:26 pm
by BenR
Many thanks for the suggestion, I've now got one on order and will have a go at creating a component for you.
Posted: Fri Jul 30, 2021 12:01 pm
by BenR
This has now been added via the update system.
Here is an example of it in use.
I2C_Multiplex_Example.fcfx
(13.55 KiB) Downloaded 502 times
The multiplexer IC is connected directly to the microcontroller and up to 8 temp/humidity sensors are connected to the CH0-CH7 of the multiplexer.
