Error in Debuger
Posted: Thu Jul 29, 2021 8:20 pm
by mehmet64
when i lunch debuger somtimes system turn crash and send this message i attach it .....
Re: Error in Debuger
Posted: Fri Jul 30, 2021 8:35 am
by Steve-Matrix
Are you using the latest v9.2 release? If not, please update and see if you get the same error with this new version.
Do you have any more information about this crash? E.g. does it happen immediately, or when attempting to run a specific command? Does the problem occur when single-stepping through the code?
It may also help if you post the project file so I can try to replicate the problem.
Posted: Mon Sep 06, 2021 9:59 am
by mehmet64
Hello this is my project////when i RUN debugger program turn Crash and close
Posted: Mon Sep 06, 2021 11:47 am
by p.erasmus
Hi.
I would advise you to switch the watchdog off when debugging and also you need to make sure you clear the watchdog in code when using in the
real application.
Posted: Mon Sep 06, 2021 4:53 pm
by mehmet64
hi
in real aplication i dont have any problem but in debuger in program when i set a bareak point FLC get in crash and close without ask any question
Posted: Mon Sep 06, 2021 5:18 pm
by Steve-Matrix
I tried your program but could not replicate the error. What version of Flowcode are you using and are you running it in the English language or another language?
Also, if you can provide a simple project and steps to replicate the issue, it will be a lot easier for us to solve the problem.
Posted: Wed Sep 08, 2021 4:13 pm
by mehmet64
hi
this problem had a somtimes not any time
