CAN BUS speed pll not work
Posted: Fri Aug 06, 2021 8:01 am
by hiromiyureei
Hello, I am using a pic 30f4013, configuring with a 8 mhz HS quartz, using the internal canbus and setting the speed to 250 kbp in effective output
oscilloscope I find myself 50 kbps, setting XT w / PLL 8x in effective output I find myself +/- 250 but if I insert a delay time of 1ms it is not respected.
thank you
Re: CAN BUS speed pll not work
Posted: Fri Aug 06, 2021 8:39 am
by LeighM
For delay times to be correct, you need to change the clock speed setting for the project,
this should now be x8 (for the PLL multiplier)
