DAC on PIC12F1572
Posted: Mon Nov 01, 2021 8:32 am
by Sergejs
Hello, dear friends!
Why if use DAC on PIC12F1572 Flowcode can not compile *.hex file? How can it be resolved?
Re: DAC on PIC12F1572
Posted: Mon Nov 01, 2021 9:39 am
by BenR
Please can you attach your .fcfx Flowcode project file and also maybe the .msg.txt file that is produced showing the errors being generated.
Posted: Mon Nov 01, 2021 9:51 am
by Sergejs
Ok. This is files what you ask.
12lf1572_dac.msg.txt
(2.3 KiB) Downloaded 610 times
12lf1572_dac.fcfx
(7.58 KiB) Downloaded 618 times
Posted: Mon Nov 01, 2021 11:54 am
by BenR
Thanks for letting us know.
The problem is caused by the datasheet and the compiler device definitions being slightly different.
I've fixed the problem for you now via the library updates system.
Posted: Mon Nov 01, 2021 3:33 pm
by Sergejs
Many thanks!
