C Code not running/working
Posted: Tue Nov 02, 2021 12:18 pm
by ntuohy
I am trying to run some c code within the project and have even tried to example in the help. But it does not run or do anything. Do I need another license? or is there a bug?
Nigel
Re: C Code not running/working
Posted: Tue Nov 02, 2021 1:01 pm
by p.erasmus
Hi ,
There can be 1000 reason why its not working ,Please do as normal people and post your FC chart with some explanation of the error you are getting,
We do not have a glass ball to see what you are doing
Posted: Tue Nov 02, 2021 4:08 pm
by ntuohy
This is the example code from the help (?) on how to use the c code
hope that helps
Nigel
Posted: Tue Nov 02, 2021 10:16 pm
Hi Nigel.
I have tried the c code on a 16F18877 and its worked as intended.
Perhaps there is an issue with your hardware?
Posted: Wed Nov 03, 2021 4:56 am
by p.erasmus
As witth Martin the code is working fine with me
Check your hardware
Posted: Wed Nov 03, 2021 9:38 am
by ntuohy
Cheers, everyone.
Will look into that..
Nige
