FlowCode STM
Posted: Tue Nov 09, 2021 10:26 am
by sulkhan
Welcome everyone.
I need your help.
We bought a new version license to work with STM microcontrollers because the older versions did not have STM support but we solved the problem.
When we try to make a break according to a specific pin (see the button and give the information, then go back and continue working from where the button went).
INTERRUPT works only on timers,
The Help and resources column says in the INT section, "Triggered when an external stimulus is used on an external interrupt (INT) pin (eg a Button press).
Is it really that hard to help in this situation?
No one you know on this forum?
I really need your help, please if anyone can respond to me
Re: FlowCode STM
Posted: Tue Nov 09, 2021 11:02 am
by LeighM
External interrupts certainly do work.
Please could you post your test Flowcode program?
(This gives us a lot of information about your scenario)
Re: FlowCode STM
Posted: Sat Nov 20, 2021 11:25 am
by sulkhan
Thanks for reply.
please tell me how can I provide project file with reply.
Re: FlowCode STM
Posted: Sat Nov 20, 2021 1:04 pm
Hi, sulkhan.
When replying, select the Attachments tab.
Select Add files
Add attachment.png (75.52 KiB) Viewed 3897 times
then a new window will open.
Browse to the folder you have your flowchart saved in, select the file that's is
Your Flowchart Name.fcfx
then select Open.
Your flowchart should then be attached to your post.
