Can not generate HEX Code for PICO
Posted: Wed Nov 24, 2021 6:10 pm
by burns
Can somebody please help? I am getting this when I try to generate the hex code for PICO.
https://www.flowcode.co.uk
Using FCD settings for compiler
Launching the compiler...
C:\ProgramData\MatrixTSL\FlowcodeV9\FCD\PICO\Batch\pico_build.bat "C:\Users\----\Downloads\pico-sdk\" "PicoBlink10" "C:\Users\Edward Burns\Desktop\"
C:\Users\----\Desktop>REM CRC: 11E85D0BF540A03612B9D5AB8A950728A3654FDC084B783F85B503651504FC6E8DA967745A187CF8FECF9115B25085A2774D1D3D69D8A99EE7320EAE740A5DB66BD212DE98DE91D9E3564078A19D1616A5C2ACA5856A86664D00059D79589982019B1EBDA9F75E245824CF181DE22D23B9DE25CDF0E36405D9066202E94705CBBDB038842E43FA4AAC72934211FD4B5DCC661788BEC7C91A063848616D51551DB978AC1A4BAF29AD4517DCDD22FC70DE135D32748FB3D1732C3050DA273BE4EE39DD52E8224900600B1F9528E97AB0BA001B0922CEB719397C7C0C9FABE651313F9A05C84301D1C0
C:\Users\----\Desktop>REM REVISION: 2.0
C:\Users\----\Desktop>REM GUID: 9EF5601F-D979-495F-89EB-F1C4F35D9212
C:\Users\----\Desktop>REM DATE: 30\07\2021
C:\Users\-----\Desktop>REM DIR: FCD\PICO\batch\pico_build.bat
ERROR: Invalid syntax. Default option is not allowed more than '2' time(s).
Type "SETX /?" for usage.
Building PicoBlink10 ...
The system cannot find the path specified.
CMake Error: The source directory "C:/Users/----/Desktop" does not appear to contain CMakeLists.txt.
Specify --help for usage, or press the help button on the CMake GUI.
'nmake' is not recognized as an internal or external command,
Build Failed
C:\ProgramData\MatrixTSL\FlowcodeV9\FCD\PICO\Batch\pico_build.bat reported error code 0x1
Autoclose turned off
FINISHED
Re: Can not generate HEX Code for PICO
Posted: Thu Nov 25, 2021 6:32 am
by p.erasmus
Have you set the path to the PICO tool chain you installed
View >> Global Options >> Locations
Posted: Thu Nov 25, 2021 8:40 am
by LeighM
Also, could you try moving your project into a path that does not contain spaces.
The space here is likely causing the issue ...
