Arduino R3 (Elegoo)
MartinSpeed
- Been thanked: 1 time
Arduino R3 (Elegoo)
Can i use Flowcode 7 with an Elegoo UNO R3 board. If so, how do i start a project.
Re: Arduino R3 (Elegoo)
Hi Martin.
Yes, it should work well as it's an Arduino Uno clone.
Just keep the same target device that's selected in this post.
To start a new project, run Flowcode, Select New Project.
Choose the target device as shown in the image within the above link.
Select OK then create variables and drag required icons into the Flowchart working area labelled Main.
If you are interested there is a getting started guide within the learning centre.
From the Project Range dropdown, select Flowcode
It's for V8 but a lot of V7 will relate to it.
