ADC Inputs
ADC Inputs
There are quiet a few devices which uses following ADC pins:
[ADCPins]
ADC0=2
ADC1=3
ADC2=4
ADC3=5
ADC4=7
ADC8=23
ADC9=24
ADC10=22
ADC11=25
ADC12=21
ADC13=26
Including 18F2221, 18F2423, 18F2523, 18F2431 Etc, but only
[ADCPins]
ADC0=2
ADC1=3
ADC2=4
ADC3=5
ADC4=7
ADC8=23
ADC9=24
Are enabled on the above devices. There are probably more devices which have ADC pins disabled, but not had time to check.
Thought this information would be useful before next Flowcode update.
Re: ADC Inputs
Hi Medelec,
Ah I wonder how those pins got missed. Ok I will sort for the next revision, thanks for the spot.
I have now updated the FCD files for the following devices,
18F2221, 18F2321, 18F2423, 18F2523.
Would you mind having a quick check to ensure that the problems have been fixed, I could not see anything wrong with the 18F2431.
Let me know if you find any more devices with similar problems and I'll make the changes to the files.
FCD_Generate_File.zip
(12.35 KiB) Downloaded 386 times
