Im using the hardware uart RS 232 (115200,9N1) for RS 485 connection => ok
Also i want to use software uart RS 232(115200,8N1) for the comunication between PIC and Edip - Displays.
Everything is working fine but the display shows nothing.
I look the data on the line and there is nothing right.
It seems to be a timing problem with software uart or code.
Configuration:
WDT off
20Mhz Xtal PLL
Target freqency 48Mhz
Software uart 115200,8,N,1
Bootloader USB
No supplymentary code or things like that.
Any suggentions?
In another topic there is a "frig - facote" or a "trick - calculation" by i can´t find out any solution for my application.
Is there any calculation or code i have to write or change baudrates?
Are the software uart and the hardware uarts independent of each other?
Please help me
Thanks guys!
