advanced settings
brandonb
- Has thanked: 175 times
- Been thanked: 173 times
advanced settings
what do these mean, do i have them set right for a 16f1939?.... the reason why im asking is i download the file to the chip and i have no glitches on harware, but when danny downloads the file he has weird things going on with the display, for instance it forgets to print string sometimes on certain menu options, or commands the wrong output on two settings, could it be a possible file corruption or external circuit noise causing it?
- setting question.jpg (82.73 KiB) Viewed 2360 times
- fotios
- Has thanked: 109 times
- Been thanked: 117 times
Re: advanced settings
Hi Brand
If the file is working without errors on one - at least - hardware stuff, then the program and the mcu settings are correct. I don't think that these "red marked" settings can cause such type issues you reffer. Check hardware.
Cheers
Fotis
Cheers
Fotis
Best Regards FOTIS ANAGNOSTOU
brandonb
hey fotios im glad to see your back
thats what i thought about the settings also (just checking) although im curious of what they do, i'll update when we get it sorted out
