Flowcode V5 examples
STibor
Has thanked: 116 times
Been thanked: 113 times
Post by STibor »
Hi!
Here is the new Flowcode5, but the example programs are the old ones, so I thought I open a new Topics V5 Flowcode example programs.
First question: How can EEpromba save the "Ulong" or "Long" variable ?
Thank you for your answers.
DavidA
Has thanked: 58 times
Been thanked: 258 times
Re: Flowcode V5 examples
Post by DavidA »
We should hopefully have some v5 specific examples coming out soon!
DavidA
Post by DavidA »
The Flowcode v5 Examples are now up in the example section of our website. http://www.matrixmultimedia.com/lc_index.php?p=18
If you want to store a long integer in the EEPROM one method would be to break that integer down into bytes and store each individual byte then programatically reform them when you require the long variable.
STibor
Post by STibor »
DavidA wrote:Hello,
Hello David!
Thank you for your answers this very question. How to split a large number of bytes? Added to my experiment.
2. Storing and retrieving 3byte long variables.fcf
(10.5 KiB) Downloaded 406 times
Hi Simpi,
Very clever.
I may need to use this in the future :wink:
STibor
Post by STibor »
Hi!
Thank you!
Here are the 4-byte program.
Tested with Pic18F252.
Data_Out3 Data_Out4 and variable type integer, byte variable error is the result.
Storing and retrieving 4byte long variables V1_1.fcf
(11.5 KiB) Downloaded 395 times
