Variabel!
jgu1
Has thanked: 1135 times
Been thanked: 299 times
Variabel!
Post by jgu1 »
Hi all! :D
I have tried to make a program where I want to enter a value into a variable via a keyboard.
I have tried without success.
Ex. I want to dial 125 in myVar then myVar 125 or (after zeroed Myvar) if I press 53 on the keyboard then myVar 53
First time I press 1 myVar is = 1
second press 2 myVar is = 12
third press 5 myVar is now =125
ect.ect.
is there anyone who has an idea, preferably without using C code.
Thank´s in advance.
Best regard
Jorgen.
Myvar.fcf
(10.5 KiB) Downloaded 310 times
Re: Variabel!
Hi jgu1,
Have you tried searching for door lock, as they use a similar method to enter a 3 or 4 digit number then compare it with a stored number to see if correct numbers have been entered.
jgu1
Re: Variabel!
Post by jgu1 »
Hi Martin!
No, good idea, I would do that if this method is the only way. Thank you Martin :D
Best regard
Jorgen.
Re: Variabel!
your welcome,
If you get stuck I will post something for you.
Mikat
Has thanked: 7 times
Been thanked: 36 times
Re: Variabel!
Post by Mikat »
Hi.
The easy way at short numbers could be like this:
First press
My_var = keyboard * 100
second press
My_var = my_var + (keyboard * 10)
third press
My_var = My_var + keyboard
Or how about an array and pointer?
Like:
Create variables Array_my_var and pointer
Array_my_var[2]
Pointer (byte)
Before first press this
Array_my_var[0] = 0
Array_my_var[1] = 0
Array_my_var[2] = 0
Pointer = 0
Then first press:
Array_my_var[Pointer] = 1
Pointer = Pointer + 1
Then second press:
Array_my_var[Pointer] = 2
Then third press:
Array_my_var[Pointer] = 5
Now the Array_my_var is:
Array_my_var[0] = 1
Array_my_var[1] = 2
Array_my_var[2] = 5
Mika
jgu1
Re: Variabel!
Post by jgu1 »
Hi Mika! :D
A bit of the same system as Martin described as the combination lock. Thank´s Mika very good explanation. I will test it later today. You will hear from me.
Best regard
Jorgen :o
Dan81
Been thanked: 60 times
Re: Variabel!
Post by Dan81 »
Hello Jorgen
Try this flowchart.
You will have to test if "number" (integer) > 32767
Daniel
keyboard2.fcf
(15.01 KiB) Downloaded 352 times
jgu1
Re: Variabel!
Post by jgu1 »
Hi Daniel!
EXACTLY just what I need! Thank you wery much. :D
Best regard
Jorgen.. :wink:
Re: Variabel!
Very clever Daniel.
I do like that method.
Dan81
Re: Variabel!
Post by Dan81 »
The same with "clear" during typing the number
Daniel
PS:
clear : *
enter : #
keyboard3.fcf
(15.64 KiB) Downloaded 339 times
jgu1
Re: Variabel!
Post by jgu1 »
Hi Daniel!
Wery nice. It´s also works wery well in real world. Now I will study your flowchart. Thank´s again. :D
Jorgen.
jgu1
Re: Variabel!
Post by jgu1 »
Hi again!
I like this: Number = (Number * 10) + keypad ( and ofcourse the rest) very, simpel easy and clever. :D
Thank´s
Jorgen.
