RTC for Miac(Part One)
acestu
Has thanked: 783 times
Been thanked: 223 times
Re: RTC for Miac(Part One)
Post by acestu »
Thanks Enamul,
I am reprogramming them right now.
Acestu
acestu
Post by acestu »
Hi Enamul,
I have reprogrammed the chips and the Master says "Master RTC Unit" but the Slave still says nothing /
thanks
Acestu
Enamul
Has thanked: 271 times
Been thanked: 814 times
Post by Enamul »
Hi Stuart,
Even if any issue in other stuff..you should at least see Time and date written in LCD. Please check your RTC module connection. I can't get anything wrong anywhere.
Enamul
University of Nottingham
enamul4mm@gmail.com
Enamul
Post by Enamul »
Have you used pull-up 4.7K resistors in SCK and SDA for RTC module?
Enamul
enamul4mm@gmail.com
acestu
Post by acestu »
Hi Enamul,
I can't see anything wrong with the rtc connection , I have just put the pull up resistors in but still the same.
I am uploading some pics
thanks
Acestu
Enamul
Post by Enamul »
Hi stuart,
Can you just test your slave module like the one you have posted before..
(88.05 KiB) Downloaded 4166 times
Enamul
enamul4mm@gmail.com
acestu
Post by acestu »
Ok,
I will put the rtc module back on that breadboard and try it
thanks
Acestu
acestu
Post by acestu »
Success at last RTC module 1 wire in wrong pin....
Acestu
Enamul
Post by Enamul »
Ok. great!
Is your CAN bus now connected?We should be able to see Time and Date in Master as well.
Enamul
enamul4mm@gmail.com
acestu
Post by acestu »
The Canbus is all connected up but the Master still says "Master RTC Unit"
Do the unused terminals on the MCP2551 need to be grounded ?
Also I have 100 ohm resisters on the Canbus thats what I used on the other unit
thanks
Acestu
Enamul
Post by Enamul »
You have tested CAN transmission earlier between Master and slave using LM35Dz as far I can remember..connection of CAN bus should be same as that..only addition is RTC module in slave which is working fine now.
OK, I have checked all my connections and found both mcp chips pins 5 to 8 back to front, I changed them and now it is sending info and returning info
Last time you did so..can you please check now MCP 2551 wiring and way it positioned.
Enamul
enamul4mm@gmail.com
acestu
Post by acestu »
As far as I can see Enamul, I have the Can bus set up the same as last time, I am enclosing a pic
thanks
Acestu
acestu
Post by acestu »
Should the Tx and Rx of the mcp chip be connected to the 4580 via 220 ohm resisters ?
thanks
Acestu
acestu
Post by acestu »
OK Enamul, I grounded pin 8 on both mcp chips and now I have date / time on both units, however I still see the "it" where "Master RTC Unit" was
thanks
Acestu
Enamul
Post by Enamul »
Sorry I was feeling so sleepy that went to bed..
That doesn't make too much difference.
It should be in the diagram I have posted earlier. PIN 8 must be grounded. That's great that you can see time in both unit.
I don't realize what you mean here.
Enamul
enamul4mm@gmail.com
acestu
Post by acestu »
Hi Enamul,
Yes I think all it is, the words "Master RTC Unit" that are on the master unit are not cleared when the date and time start so that the last letters ie "it" are still visible on the screen, that's all I meant. I think if I shorten it to "Master RTC" in the code you should no longer see it.
thanks
Acestu
Enamul
Post by Enamul »
Don't worry..It's pretty easy problem. I will correct code when I will back home. Great work. Well done :)
Now we are ready for MIAC
Enamul
enamul4mm@gmail.com
acestu
Post by acestu »
Ok thats great Enamul
thanks
Acestu
Enamul
Post by Enamul »
Hi Stuart,
Here is the final without display issue..Please test that and let me know. I am going to make new thread for MIAC. Do you have your MIAC in hand already?
RTC_PIC18f4580_MASTER.fcf
(23.79 KiB) Downloaded 442 times
RTC_PIC18f4580_SLAVE.fcf
(48.54 KiB) Downloaded 396 times
Enamul
enamul4mm@gmail.com
acestu
Post by acestu »
Hi Enamul,
I will do that now, also I have the brand new shiny MIAC right next to me ready for action.
Stuart
acestu
Post by acestu »
Hi Enamul, that has done the job
Acestu
Enamul
Post by Enamul »
Excellent Work! You have done it!
Enamul
enamul4mm@gmail.com
acestu
Post by acestu »
WoW brilliant, Thank you Enamul, I will break out the champagne,
The Guinness book of records have been on the phone, we have broken the longest ever thread on a Forum World Record lol....
Acestu
JohnCrow
Has thanked: 364 times
Been thanked: 716 times
Post by JohnCrow »
Been an interesting thread to follow.
Got my own ideas based on this, once I have finished another project.
acestu
Post by acestu »
Thanks John,
that sounds interesting, I will post the final drawings and pics on this thread when I have finished part 2.
Acestu
