Someone was asking on what bench power supplies that people where using for exerimenting with E Blocks and there projects.
My first unit was made from from a old 14V battery drill charger unit that i had spare from a failed unit the insides where chucked away and the case was just used for holding the battery, a On/Off switch was fitted several terminals for 14V and 5V outputs inside there was a LT1003 5Volt 5Amp regulator on a big heatsink at the back with some fuses on the output . Bit of a pain having to charge up the battrey every now and again used this for aprox 1 year
I then sumbled across a Cosel 5V 5Amp power supply still in its original box at a local radio ham fair, the guy obviously didn't know what he was selling and i bought it for £5
Got a box made at work and used that for quite a long time (still use it sometimes)
I stumbled across a Farnell Tops 2 Power supply ( 5v 5Amp +/- 15 V 1Amp) on Ebay. Again the guy obviously didn't know what he was selling a grabbed my self a bargin at £40 delviered however it it quite big and heavy bidding started at 99p .
There are quite a few of the farnell power supplys popping up on ebay so keep an eye out and grab your self a bargin , there is a tops 1 power supply but the current outputs are signifacntly lower ,
The LT30 /2 farnell power supplies they also pop up on ebay also but tend to go quite quicky and are very sort after items and the auctions can go silly, good power supply but big and heavy.
Hope this is of some help
