What's the equivalence in seconds for nTimeout?
Carmen Garcia
- Has thanked: 14 times
- Been thanked: 3 times
Hello everybody:
In ZigBee's Macro "Receive_Char" is used the input paramenter "nTimeout" that's not means seconds (time), it means how much munber of retries to check for a response...
¿Does anyone know the equivalence between this retries and the seconds between them?
Thanks you very much in advanced.
Carmen Garcia
kersing
- Has thanked: 553 times
- Been thanked: 1081 times
Re: What's the equivalence in seconds for nTimeout?
Answer for Flowcode 5:
Each try of nTimeout is 1000 microseconds. Value 255 is a special (wait forever) value.
― C.S. Lewis
― C.S. Lewis
Carmen Garcia
Thank you very very much¡¡
Carmen Garcia
kersing
I checked the component sources.
― C.S. Lewis
― C.S. Lewis
Carmen Garcia
Hi Carmen
if you add a zigbee component right click it ,click help and its in the helpfile that pops up
Dazz
Dazz
Carmen Garcia
Hi Dazz:
I was looking for this information throught this way and doesn't appear anything like this...My FlowCode version is 5 too.
Carmen Garcia
Hi Carmen
see attached pic ,not sure if you were looking at the correct help file
1 right click select help
2 click the 3 dots opposite help
3 line explaining ntimeout
Dazz
Dazz
- (746.64 KiB) Downloaded 3525 times
Hi Jaqkersing wrote:Answer for Flowcode 5:
I thought it was 100us as per the uart. cal file
Dazz
Carmen Garcia
Thanks you very much for the picture
This is the flow I followed...but the UART.cal file is the key for solve my doubt.
How do you view to this file?
Thanks you very much again.
Carmen Garcia
kersing
Dazz,dazz wrote:I thought it was 100us as per the uart. cal file
The way I read the code is:
In the code of FC_CAL_UART_Receive there is a loop (rxStatus == UART_STATUS_LOOP) that waits 10us, increments delay1 and only if delay1 equals 100, nTimeout is decremented.
That makes 100 times 10 us = 1000 us delay for each decrement of nTimeout.
Jac
― C.S. Lewis
― C.S. Lewis
kersing
Use your favorite editor to open c:\Program Files\Flowcode\v5\CAL\PIC\PIC_CAL_UART.c (for 64 bit systems it is c:\Program Files (x86)\Flowcode\v5\CAL\PIC\PIC_CAL_UART.c)Carmen Garcia wrote: How do you view to this file?
― C.S. Lewis
― C.S. Lewis
Hi Jac
cheers i missed the loop
Dazz
Dazz
