MIAC - Advanced expansion module
gangusgreen
Has thanked: 6 times
Post by gangusgreen »
Is it possible to run this module as it's own controller? And if so can V5 flowcode work with this?
JohnCrow
Has thanked: 364 times
Been thanked: 716 times
Re: MIAC - Advanced expansion module
Post by JohnCrow »
Miac and expansion information is available here
http://www.matrixmultimedia.com/miac.php
The advancesd module connects to the MIAC by the CAN BUS (i.e 2 wire twisted pair), but flowcode makes it totally transparent so you dont need to understand CAN protocols. All taken care of by FC.
But it cannot be used on its own under FC. (i.e without the MIAC)
Ive never thought about using them on there own, but I suspose if you have a very good understanding of the CAN bus protocols it may be possible.
But you would still need the CAN controller E-Block and a EB006 or other upstream board to control it.
Im sure MM will be able to say yes or no on this
LeighM
Has thanked: 481 times
Been thanked: 699 times
Post by LeighM »
Hi gangusgreen
As John mentioned there are more detailed documents available on the MIAC web page.
This includes a document outlining how we use the CAN protocol to control the functionality of the expansion modules, and also how to re-program their CAN IDs if you so require. So in this way the modules can be used within an existing CAN network.
But as John said they are most easily used via FC5 and the MIAC.
The expansion modules themselves come pre-loaded with the Firmware necessary to operate as part of a MIAC System, with the controlling software developed easily on FC5 and targeting the controlling MIAC.
However, it is also possible to re-program the expansion modules for your own purposes, via a PICKit interface and using FC5 for dsPIC. This though is a more advanced task.
Leigh
gangusgreen
Hi Leigh,
Is there a port for the PicKit3 on the module?
Bill
JohnCrow
Post by JohnCrow »
Hi Bill
Yes, its on the PCB inside the unit.
Carefully unclip the board from the back of the case. Watch the wires to the LED on the front they are quite short, its best to push the led back out of its clip.
Ive used it to update the firmware on them.
gangusgreen
Thanks for the info John. :D
Bill
