Transparent windows
MJU
Has thanked: 121 times
Been thanked: 108 times
Transparent windows
Post by MJU »
Hard to explain, but when I open certain panels in V6, they are "transparent".
They show (in some panels), a part of the previous opened screen.
The scope doesn't work, it stays "transparent", I never get a way of adding signals to the scope.
In this screencapture I will try to show what I mean wit "transparent" windows.
The window that I opened shows the MM forum I opened before this window in V6.
(125.82 KiB) Downloaded 364 times
The scope should be visible (is active in the view dropdown list), but I can't find it.
The "console window" has the content of the matrix-forum.
Any suggestions?
Thank you
JonnyW
Has thanked: 63 times
Been thanked: 290 times
Re: Transparent windows
Post by JonnyW »
Hi.
Hmm... this looks like an OpenGL issue. What about the system and dashboard panels, are these OK? Do you have two monitors possibly and do you know what graphics card you are using?
If you PM me with the details of your graphics card, and have a look on the Flowcode 'About' screen for an OpenGL version, I can perhaps put some debug together to find out what the problem is and where things are failing. Problem with OpenGL is that there are a lot of different versions and some combinations of HW and GL cause issues. Hopefully we can find out where things are going wrong.
Jonny
