I have a Flowcode V5.5 ARM and I search ST7565R GLcd Component. I try with old version of Custom.c but I have many problem.
t.c:6080: error: 'portd' undeclared (first use in this function)
t.c:6080: error: (Each undeclared identifier is reported only once
t.c:6080: error: for each function it appears in.)
t.c: At top level:
t.c:6090: error: conflicting types for 'MX_Write_Command'
t.c:6071: error: previous declaration of 'MX_Write_Command' was here
t.c: In function 'MX_Write_Command':
t.c:6091: error: 'portd' undeclared (first use in this function)
t.c:6094: error: 'trisb' undeclared (first use in this function)
t.c:6095: error: 'portb' undeclared (first use in this function)
t.c: In function 'MX_WriteData':
t.c:6129: error: 'portd' undeclared (first use in this function)
t.c:6132: error: 'trisb' undeclared (first use in this function)
t.c:6142: error: 'portb' undeclared (first use in this function)
t.c: In function 'MX_ReadData':
t.c:6170: error: 'portb' undeclared (first use in this function)
t.c:6171: error: 'trisb' undeclared (first use in this function)
t.c:6172: error: 'portd' undeclared (first use in this function)
t.c: In function 'FCD_Custom0_LCD_Init':
t.c:6199: error: 'trisb' undeclared (first use in this function)
t.c:6200: error: 'portb' undeclared (first use in this function)
t.c:6203: error: 'trisd' undeclared (first use in this function)
t.c:6209: error: 'portd' undeclared (first use in this function)
and
t.c:6050: error: syntax error before 'char'
...Code: Select all
* Flowcode Custom Component Code
* File: Custom_Code.c
* (c) 2008 Matrix Multimedia Ltd.
* http://www.matrixmultimedia.com
* Software License Agreement
* The software supplied herewith by Matrix Multimedia Ltd (the
* “Company”) for its Flowcode graphical programming language is
* intended and supplied to you, the Company’s customer, for use
* solely and exclusively on the Company's products. The software
* is owned by the Company, and is protected under applicable
* copyright laws. All rights are reserved. Any use in violation
* of the foregoing restrictions may subject the user to criminal
* sanctions under applicable laws, as well as to civil liability
* for the breach of the terms and conditions of this licence.
* THIS SOFTWARE IS PROVIDED IN AN “AS IS” CONDITION. NO WARRANTIES,
* WHETHER EXPRESS, IMPLIED OR STATUTORY, INCLUDING, BUT NOT LIMITED
* TO, IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A
* PARTICULAR PURPOSE APPLY TO THIS SOFTWARE. THE COMPANY SHALL NOT,
* IN ANY CIRCUMSTANCES, BE LIABLE FOR SPECIAL, INCIDENTAL OR
* CONSEQUENTIAL DAMAGES, FOR ANY REASON WHATSOEVER.
* Changelog:
* date | by | description
* 050508 | BR | Created
Return & parameter types:
void
char
short
char*
Pin directions:
0 = OUTPUT
2 = INPUT
3 = BIDIRECTIONAL
Macro substitutions:
%a = ??
%b = ??
%c = ??
%d = ??
%e = ??
%f = ??
%g = ??
%h = ??
%i = ??
%j = ??
[Settings]
CLSID={4B174520-75AB-4B14-A0F7-2AA6C203F1DC}
IsAnalogue=0
MultipleAllowed=0
Description=Custom Flowcode Component
[Port]
DesiredPort=0
PortMandatory=0
SamePortAsID=0
[Pins]
Count=0
[PinPort]
# PORTA = 0
# PORTB = 1
# PORTC = 2
# PORTD = 3
# PORTE = 4
[PinDesiredBit]
[PinDirection]
# DIR_INPUT = 2
# DIR_OUTPUT = 0
# DIR_BIDIRECTIONAL = 3
[PinMustUsePort]
# char
[SamePortAsPinX]
# -1 = any pin
# otherwise, the pin number
[PinMustUsePin]
# char
[PinValue]
# char (0 = off, 1 = on)
[MacroNames]
Count=9
1=GetDefines
2=LCD_Init
3=LCD_Clear
4=LCD_PlotPixel
5=LCD_Draw_Line
6=LCD_Draw_Rect
7=LCD_Print_String
8=LCD_Print_Number
9=LCD_Invert_Rect
[MacroReturns]
1=void
2=void
3=void
4=void
5=void
6=void
7=void
8=void
9=void
[MacroIsPrivate]
1=1
2=0
3=0
4=0
5=0
6=0
7=0
8=0
9=0
[MacroParameters_GetDefines]
Count=0
[MacroParamTypes_GetDefines]
[MacroParameters_LCD_Init]
Count=0
[MacroParamTypes_LCD_Init]
[MacroParameters_LCD_Clear]
Count=0
[MacroParamTypes_LCD_Clear]
[MacroParameters_LCD_PlotPixel]
Count=3
1=x
2=y
3=colour
[MacroParamTypes_LCD_PlotPixel]
1=char
2=char
3=char
[MacroParameters_LCD_Draw_Line]
Count=5
1=x
2=y
3=x2
4=y2
5=colour
[MacroParamTypes_LCD_Draw_Line]
1=char
2=char
3=char
4=char
5=char
[MacroParameters_LCD_Draw_Rect]
Count=5
1=x
2=y
3=width
4=height
5=colour
[MacroParamTypes_LCD_Draw_Rect]
1=char
2=char
3=char
4=char
5=char
[MacroParameters_LCD_Print_String]
Count=6
1=String
2=X
3=Y
4=Font
5=Transparent
6=Colour
[MacroParamTypes_LCD_Print_String]
1=char*
2=char
3=char
4=char
5=char
6=char
[MacroParameters_LCD_Print_Number]
Count=6
1=Number
2=X
3=Y
4=Font
5=Transparent
6=Colour
[MacroParamTypes_LCD_Print_Number]
1=short
2=char
3=char
4=char
5=char
6=char
[MacroParameters_LCD_Invert_Rect]
Count=4
1=x
2=y
3=width
4=height
[MacroParamTypes_LCD_Invert_Rect]
1=char
2=char
3=char
4=char
* ADDITIONAL CODE
/*InitialisationCode_Start*/
/*InitialisationCode_End*/
/*InterruptCode_Start*/
/*InterruptCode_End*/
* FUNCTIONS
void GetDefines()
/*Macro_GetDefines_Start*/
} //Dummy end of function to allow defines to be added correctly
//Flowcode Defines
#define MX_DATA_PORT portb //%a
#define MX_DATA_TRIS trisb //%b
#define MX_CONTROL_PORT portd //%c
#define MX_CONTROL_TRIS trisd //%d
#define MX_CS1 0 //%e - CS1
#define MX_CON_RES 3 //%f - /RST
#define MX_DAT_INST 4 //%g - A0
#define MX_READ_WRITE 5 //%h - /WR
#define MX_ENABLE 6 //%i - /RD
//Static defines
#define MX_BLACK 0xFF
#define MX_WHITE 0x00
//ASCII Pixel data
rom char* ASCII1 = {0x00 , 0x00 , 0x00 , 0x00 , 0x00, // space // 32 - 43
0x00 , 0x06 , 0x5F , 0x06 , 0x00, // !
0x07 , 0x03 , 0x00 , 0x07 , 0x03, // ''
0x24 , 0x7E , 0x24 , 0x7E , 0x24, // #
0x24 , 0x2B , 0x6A , 0x12 , 0x00, // $
0x63 , 0x13 , 0x08 , 0x64 , 0x63, // %
0x36 , 0x49 , 0x56 , 0x20 , 0x50, // &
0x00 , 0x07 , 0x03 , 0x00 , 0x00, // '
0x00 , 0x3E , 0x41 , 0x00 , 0x00, // (
0x00 , 0x41 , 0x3E , 0x00 , 0x00, // )
0x08 , 0x3E , 0x1C , 0x3E , 0x08, // *
0x08 , 0x08 , 0x3E , 0x08 , 0x08}; // +
rom char* ASCII2 = {0x00 , 0xE0 , 0x60 , 0x00 , 0x00, // , // 44 - 55
0x08 , 0x08 , 0x08 , 0x08 , 0x08, // -
0x00 , 0x60 , 0x60 , 0x00 , 0x00, // .
0x20 , 0x10 , 0x08 , 0x04 , 0x02, // /
0x3E , 0x51 , 0x49 , 0x45 , 0x3E, // 0
0x00 , 0x42 , 0x7F , 0x40 , 0x00, // 1
0x62 , 0x51 , 0x49 , 0x49 , 0x46, // 2
0x22 , 0x49 , 0x49 , 0x49 , 0x36, // 3
0x18 , 0x14 , 0x12 , 0x7F , 0x10, // 4
0x2F , 0x49 , 0x49 , 0x49 , 0x31, // 5
0x3C , 0x4A , 0x49 , 0x49 , 0x30, // 6
0x01 , 0x71 , 0x09 , 0x05 , 0x03}; // 7
rom char* ASCII3 = {0x36 , 0x49 , 0x49 , 0x49 , 0x36, // 8 // 56 - 67
0x06 , 0x49 , 0x49 , 0x29 , 0x1E, // 9
0x00 , 0x6C , 0x6C , 0x00 , 0x00, // :
0x00 , 0xEC , 0x6C , 0x00 , 0x00, // ;
0x08 , 0x14 , 0x22 , 0x41 , 0x00, // <
0x24 , 0x24 , 0x24 , 0x24 , 0x24, // =
0x00 , 0x41 , 0x22 , 0x14 , 0x08, // >
0x02 , 0x01 , 0x59 , 0x09 , 0x06, // ?
0x3E , 0x41 , 0x5D , 0x55 , 0x1E, // @
0x7E , 0x09 , 0x09 , 0x09 , 0x7E, // A
0x7F , 0x49 , 0x49 , 0x49 , 0x36, // B
0x3E , 0x41 , 0x41 , 0x41 , 0x22}; // C
rom char* ASCII4 = {0x7F , 0x41 , 0x41 , 0x41 , 0x3E, // D // 68 - 79
0x7F , 0x49 , 0x49 , 0x49 , 0x41, // E
0x7F , 0x09 , 0x09 , 0x09 , 0x01, // F
0x3E , 0x41 , 0x49 , 0x49 , 0x7A, // G
0x7F , 0x08 , 0x08 , 0x08 , 0x7F, // H
0x00 , 0x41 , 0x7F , 0x41 , 0x00, // I
0x30 , 0x40 , 0x40 , 0x40 , 0x3F, // J
0x7F , 0x08 , 0x14 , 0x22 , 0x41, // K
0x7F , 0x40 , 0x40 , 0x40 , 0x40, // L
0x7F , 0x02 , 0x04 , 0x02 , 0x7F, // M
0x7F , 0x02 , 0x04 , 0x08 , 0x7F, // N
0x3E , 0x41 , 0x41 , 0x41 , 0x3E}; // O
rom char* ASCII5 = {0x7F , 0x09 , 0x09 , 0x09 , 0x06, // P // 80 - 91
0x3E , 0x41 , 0x51 , 0x21 , 0x5E, // Q
0x7F , 0x09 , 0x09 , 0x19 , 0x66, // R
0x26 , 0x49 , 0x49 , 0x49 , 0x32, // S
0x01 , 0x01 , 0x7F , 0x01 , 0x01, // T
0x3F , 0x40 , 0x40 , 0x40 , 0x3F, // U
0x1F , 0x20 , 0x40 , 0x20 , 0x1F, // V
0x3F , 0x40 , 0x3C , 0x40 , 0x3F, // W
0x63 , 0x14 , 0x08 , 0x14 , 0x63, // X
0x07 , 0x08 , 0x70 , 0x08 , 0x07, // Y
0x71 , 0x49 , 0x45 , 0x43 , 0x00, // Z
0x00 , 0x7F , 0x41 , 0x41 , 0x00}; // [
rom char* ASCII6 = {0x02 , 0x04 , 0x08 , 0x10 , 0x20, // \ // 92 - 103
0x00 , 0x41 , 0x41 , 0x7F , 0x00, // ]
0x04 , 0x02 , 0x01 , 0x02 , 0x04, // ^
0x80 , 0x80 , 0x80 , 0x80 , 0x80, // _
0x00 , 0x03 , 0x07 , 0x00 , 0x00, // `
0x20 , 0x54 , 0x54 , 0x54 , 0x78, // a
0x7F , 0x44 , 0x44 , 0x44 , 0x38, // b
0x38 , 0x44 , 0x44 , 0x44 , 0x28, // c
0x38 , 0x44 , 0x44 , 0x44 , 0x7F, // d
0x38 , 0x54 , 0x54 , 0x54 , 0x18, // e
0x08 , 0x7E , 0x09 , 0x09 , 0x00, // f
0x18 , 0xA4 , 0xA4 , 0xA4 , 0x7C}; // g
rom char* ASCII7 = {0x7F , 0x04 , 0x04 , 0x78 , 0x00, // h // 104 - 115
0x00 , 0x00 , 0x7D , 0x00 , 0x00, // i
0x40 , 0x80 , 0x84 , 0x7D , 0x00, // j
0x7F , 0x10 , 0x28 , 0x44 , 0x00, // k
0x00 , 0x00 , 0x7F , 0x40 , 0x00, // l
0x7C , 0x04 , 0x18 , 0x04 , 0x78, // m
0x7C , 0x04 , 0x04 , 0x78 , 0x00, // n
0x38 , 0x44 , 0x44 , 0x44 , 0x38, // o
0xFC , 0x44 , 0x44 , 0x44 , 0x38, // p
0x38 , 0x44 , 0x44 , 0x44 , 0xFC, // q
0x44 , 0x78 , 0x44 , 0x04 , 0x08, // r
0x08 , 0x54 , 0x54 , 0x54 , 0x20}; // s
rom char* ASCII8 = {0x04 , 0x3E , 0x44 , 0x24 , 0x00, // t // 116 - 126
0x3C , 0x40 , 0x20 , 0x7C , 0x00, // u
0x1C , 0x20 , 0x40 , 0x20 , 0x1C, // v
0x3C , 0x60 , 0x30 , 0x60 , 0x3C, // w
0x6C , 0x10 , 0x10 , 0x6C , 0x00, // x
0x9C , 0xA0 , 0x60 , 0x3C , 0x00, // y
0x64 , 0x54 , 0x54 , 0x4C , 0x00, // z
0x08 , 0x3E , 0x41 , 0x41 , 0x00, // {
0x00 , 0x00 , 0x7F , 0x00 , 0x00, // |
0x00 , 0x41 , 0x41 , 0x3E , 0x08, // }
0x02 , 0x01 , 0x02 , 0x01 , 0x00}; // ~
//Global Variables
char mx_page;
char mx_currentx;
char mx_currenty;
//Internal Prototypes
void MX_LCD_Enable (void);
void MX_Write_Command(char cmd, char chip);
void GotoXY(char x, char y);
void MX_WriteData(char data);
char MX_ReadData(void);
//Internal Functions
set_bit(MX_CONTROL_PORT, MX_ENABLE);
nop();
nop();
clear_bit(MX_CONTROL_PORT, MX_ENABLE);
nop();
nop();
void MX_Write_Command (char cmd)
clear_bit(MX_CONTROL_PORT, MX_READ_WRITE); //Write Command
clear_bit(MX_CONTROL_PORT, MX_DAT_INST); //Instruction code
clear_bit(MX_CONTROL_PORT, MX_CS1);
MX_DATA_TRIS = 0x00; //Configure data port as output
MX_DATA_PORT = cmd;
MX_LCD_Enable();
MX_DATA_PORT = 0x00;
set_bit(MX_CONTROL_PORT, MX_CS1);
void MX_GotoXY (char x, char y)
char page, columnl, columnh;
page = (y / 8) | 0xB0;
columnh = (x >> 4) | 0x10;
columnl = x & 0x0F;
if(x > 127) x = 0; //Ensure that coordinates are legal
if(y > 63) y = 0;
mx_currentx = x;
mx_currenty = y;
mx_page = y / 8;
MX_Write_Command(0x40); //set display start line
MX_Write_Command(page); //set page address
MX_Write_Command(columnh); //set column address
MX_Write_Command(columnl);
void MX_WriteData (char data)
char displayData, yOffset, cmdPort;
set_bit(MX_CONTROL_PORT, MX_DAT_INST); //Configure to send data
clear_bit(MX_CONTROL_PORT, MX_READ_WRITE); //Configure to write data
MX_DATA_TRIS = 0x00; //Configure data port to Output
yOffset = mx_currenty % 8;
if(yOffset != 0) //First page?
cmdPort = MX_CONTROL_PORT; //Save command port
displayData = MX_ReadData();
MX_CONTROL_PORT = cmdPort; //Restore command port
MX_DATA_TRIS = 0x00; //Data port is output
displayData = displayData | (data << yOffset);
MX_DATA_PORT = displayData; //Write data
MX_LCD_Enable(); //Enable
// second page
MX_GotoXY(mx_currentx, (mx_currenty + 8));
displayData = displayData | (data >> (8-yOffset));
MX_GotoXY(mx_currentx + 1, (mx_currenty - 8));
else
MX_DATA_PORT = data; //Write data
mx_currentx = mx_currentx + 1;
char MX_ReadData (void)
char data, i;
MX_DATA_TRIS = 0xFF; //Data port is input
set_bit(MX_CONTROL_PORT, MX_READ_WRITE); //Configure to read data
nop();
nop();
data = MX_DATA_PORT; //Read Data
MX_DATA_TRIS = 0x00; //Configure port as output
MX_GotoXY(mx_currentx, mx_currenty);
return data;
// Dummy function to close the defines section off
void CUSTOM_Dummy_Function();
/*Macro_GetDefines_End*/
void LCD_Init ()
/*Macro_LCD_Init_Start*/
mx_currentx = 0;
mx_currenty = 0;
mx_page = 0;
MX_DATA_TRIS = 0x00; //Convert data port to output
clear_bit(MX_CONTROL_TRIS, MX_ENABLE); //Convert control pins to output
clear_bit(MX_CONTROL_TRIS, MX_DAT_INST);
clear_bit(MX_CONTROL_TRIS, MX_CS1);
clear_bit(MX_CONTROL_TRIS, MX_CON_RES);
clear_bit(MX_CONTROL_TRIS, MX_READ_WRITE);
clear_bit(MX_CONTROL_PORT, MX_CON_RES); //Make sure device is in reset mode
delay_10us(1); //Allow display power to stabilise
set_bit(MX_CONTROL_PORT, MX_CON_RES); //Switch on device
delay_ms(1); //Wait for device to reach initialised state
//Commands
MX_Write_Command(0xA2); //11 LCD BIAS
MX_Write_Command(0xA0); //8 ADC Selection
MX_Write_Command(0xC8); //15 Common Output Mode
MX_Write_Command(0x25); //17 Regulator Resistor Ratio
MX_Write_Command(0x81); //18 Electronic Volume Control
MX_Write_Command(0x20); //18 Electronic Volume Register Set
MX_Write_Command(0xF8); //16 Booster Ratio 4x
MX_Write_Command(0x00);
MX_Write_Command(0x2F); //Power Control
LCD_Draw_Rect(0, 0, 127, 63, MX_WHITE); //Initialise DDRAM
MX_Write_Command(0xAC); //Static indicator off
MX_Write_Command(0xA6); //Normal Display
MX_GotoXY(0,0);
/*Macro_LCD_Init_End*/
void LCD_Clear ()
/*Macro_LCD_Clear_Start*/
/*Macro_LCD_Clear_End*/
void LCD_PlotPixel (char x, char y, char colour)
/*Macro_LCD_PlotPixel_Start*/
char data, mod_y;
mod_y = y%8;
MX_GotoXY(x, y);
data = MX_ReadData(); //Read 8 pixels from display
if (colour)
data = data | (0x01 << mod_y); //Set Pixel
else
data = data & (~(0x01 << mod_y)); //Clear Pixel
MX_WriteData(data);
/*Macro_LCD_PlotPixel_End*/
void LCD_Draw_Line (char x, char y, char x2, char y2, char colour)
/*Macro_LCD_Draw_Line_Start*/
int C1, M1;
signed int D1 = 0;
signed int Pixelx = x2 - x; //number of X-pixels;
signed int Pixely = y2 - y; //Number of Y-pixels
signed char Xinc = 1;
signed char Yinc = 1;
if (Pixelx < 0) //If negative X direction
Xinc = -1;
Pixelx = Pixelx * -1;
if (Pixely < 0) //If negative Y direction
Yinc = -1;
Pixely = Pixely * -1;
if (Pixely <= Pixelx)
C1 = 2 * Pixelx;
M1 = 2 * Pixely;
while (x != x2)
LCD_PlotPixel(x, y, colour); //ForePlot line
x = x + Xinc;
D1 = D1 + M1;
if (D1 > Pixelx)
y = y + Yinc;
D1 = D1 - C1;
else
C1 = 2 * Pixely;
M1 = 2 * Pixelx;
while (y != y2)
LCD_PlotPixel(x, y, colour); //ForePlot Line
y = y + Yinc;
D1 = D1 + M1;
if (D1 > Pixely)
x = x + Xinc;
D1 = D1 - C1;
/*Macro_LCD_Draw_Line_End*/
void LCD_Draw_Rect (char x, char y, char width, char height, char colour)
/*Macro_LCD_Draw_Rect_Start*/
char mask, pageOffset, h, i, data;
if(colour)
colour = 255;
height = height + 1;
pageOffset = y % 8;
y = y - pageOffset;
mask = 0xFF;
if(height < (8 - pageOffset))
mask = mask >> (8-height);
h = height;
else
h = (8 - pageOffset);
mask = mask << pageOffset;
MX_GotoXY(x, y);
for(i=0; i<=width; i++)
if(colour)
data = data | mask;
else
data = data & (~mask);
MX_WriteData(data);
while((h + 8) <= height)
h = h + 8;
y = y + 8;
MX_GotoXY(x, y);
MX_WriteData(colour);
if(h < height)
mask = ~(0xFF << (height - h));
MX_GotoXY(x, (y + 8));
if(colour)
data = data | mask;
else
MX_WriteData(data);
/*Macro_LCD_Draw_Rect_End*/
void LCD_Print_String (char* String, char X, char Y, char Font, char Transparent, char Colour)
/*Macro_LCD_Print_String_Start*/
char xpix, ypix, pos_Str, count, xcount, ycount, height, width, i;
char Fontwidth = 1; //First we assume small font
char Fontheight = 1;
char inv_colour = 1;
char temp[6];
temp[5] = 0x00; //Spacing Line
if (Colour)
inv_colour = 0;
if (Font == 1) //Double Height Sizes //Double Width
Fontwidth = 2;
if (Font == 2) //Double Height and Width Sizes
Fontwidth = 2;
Fontheight = 2;
if (Font == 3) //Double Height Sizes
Fontheight = 2;
xcount = 0;
for (i=0;i<MSZ_String;i++) //Start at beginning of string and work along
if (String[i] == 0)
return;
pos_Str = String[i] - 32; //Calculate place in ASCII memory
for (count = 0; count < 5; count++) //Use correct buffer location
if (pos_Str < 12)
temp[count]=ASCII1[(pos_Str*5)+count];
else if (pos_Str < 24)
temp[count]=ASCII2[((pos_Str - 12)*5)+count];
else if (pos_Str < 36)
temp[count]=ASCII3[((pos_Str - 24)*5)+count];
else if (pos_Str < 48)
temp[count]=ASCII4[((pos_Str - 36)*5)+count];
else if (pos_Str < 60)
temp[count]=ASCII5[((pos_Str - 48)*5)+count];
else if (pos_Str < 72)
temp[count]=ASCII6[((pos_Str - 60)*5)+count];
else if (pos_Str < 84)
temp[count]=ASCII7[((pos_Str - 72)*5)+count];
else if (pos_Str < 95)
temp[count]=ASCII8[((pos_Str - 84)*5)+count];
for (xpix=0;xpix<6;xpix++) //For 6 ASCII bytes 0 - 5
for (width=0;width<Fontwidth;width++)
ycount = 0;
for (ypix=0;ypix<8;ypix++) //For 8 data bits in bytes 0 - 7
for (height=0;height<Fontheight;height++)
if (test_bit(temp[xpix],ypix))
LCD_PlotPixel(X + xcount, Y + ycount, Colour);
else if (Transparent == 0)
LCD_PlotPixel(X+xcount, Y+ycount, inv_colour);
ycount++;
xcount++;
/*Macro_LCD_Print_String_End*/
void LCD_Print_Number (short Number, char X, char Y, char Font, char Transparent, char Colour)
/*Macro_LCD_Print_Number_Start*/
char string_length;
if (Number < -10000 )
string_length = 6;
else if(Number > 10000 || Number < -1000)
string_length = 5;
else if(Number > 1000 || Number < -100)
string_length = 4;
else if(Number > 100 || Number < -10)
string_length = 3;
else if(Number > 10 || Number < -1)
string_length = 2;
else
string_length = 1;
char temp_str[6];
FCI_TOSTRING(Number,temp_str,string_length); //Convert number to String
LCD_Print_String(temp_str, string_length, X, Y, Font, Transparent, Colour); //Send string to Print function
/*Macro_LCD_Print_Number_End*/
void LCD_Invert_Rect (char x, char y, char width, char height)
/*Macro_LCD_Invert_Rect_Start*/
char mask, pageOffset, h, i, data, tmpData;
height++;
pageOffset = y % 8;
y = y - pageOffset;
mask = 0xFF;
h = height;
else
h = 8 - pageOffset;
MX_GotoXY(x, y);
tmpData = ~data;
data = (tmpData & mask) | (data & ~mask);
MX_WriteData(data);
h = h + 8;
y = y + 8;
MX_GotoXY(x, y);
MX_WriteData(~data);
if(h < height)
mask = ~(0xFF << (height-h));
MX_GotoXY(x, y+8);
tmpData = ~data;
MX_WriteData(data);
/*Macro_LCD_Invert_Rect_End*/
}Thank you very much
