Error "float32_sqrt" when compiling
billduck
Has thanked: 23 times
Been thanked: 16 times
Post by billduck »
I get "undefined reference to "float32_sqrt" when compiling to hex. I did a search on "float32_sqrt", and found that I had a similar problem in 2011, for which a new internals.h file was supplied. I am reticent to apply the old fix. What should I do?
I am using FC5.5 AVR
Thanks.
SquareRootProblem.fcf_avr
Compile this to show error.
(5.5 KiB) Downloaded 264 times
Re: Error "float32_sqrt" when compiling
This attachment should fix the issue if you place it into your "C:\Program Files (x86)\Flowcode(AVR)\v5\CAL\AVR" folder.
AVR_CAL_Float.c
(3.04 KiB) Downloaded 347 times
billduck
Post by billduck »
It did the job. Thanks.
