Hi Team,
Iam not able to make work the LCd display in PIC18F86J60. I added the schematic FYI. Kindly help me out. I also added the Simple program of LCD dsiplay.
Pls.
Cant able to make lCD work in PIC18F86J60
- Connections.pdf
- (236.17 KiB) Downloaded 223 times
Re: Cant able to make lCD work in PIC18F86J60
pls find the Flow code file
- LCD.fcf
- (6.5 KiB) Downloaded 220 times
And Im also failed to code the RS232 components and make it work on bord. Kindly explain me that how to proceed or this is the BUG ?
- Has thanked: 553 times
- Been thanked: 1081 times
Does a simple 1 second flasher (LED on/LED off) using the LED connected to RJ5 work?
― C.S. Lewis
― C.S. Lewis
This is working. I added the file for your reference.
- Flowcode1.fcf
- (7 KiB) Downloaded 221 times
Hi karthik.devaraj,
To get further help on the device your using, you must first register for the V5 section,
See:
http://www.matrixmultimedia.com/mmforum ... =46&t=9958
Once your registered further should will be available.
See:
