glcd designing app
Please add any feature requests for Flowcode version 6 here
Forum rules
Only feature requests will be considered here. General questions should not be posted in this forum.
Afsal
Been thanked: 5 times
glcd designing app
Post by Afsal »
visual tft is a great tools from Mikro electronica, if get some thing like in Fcv6 will be greatfull.
FT 800 is power full chip from FTDI for glcd. if fcv6 support this chip would be greatfull.
RTOS is the other option unfortunately FCV 6 is not supporting.
Re: glcd designing app
Cheers for the suggestions. I have recently implemented Visi for 4D systems and Visual TFT looks very similar so will have a go at doing this too.
John_RSD
Has thanked: 3 times
Been thanked: 2 times
Post by John_RSD »
Did you guys ever get support for the FT800 up and running ?
John
Many thanks
John
No but looking at it it does look quite good and is based around SPI. I'll add it to the list and see if I can get some time to add it in.
I've cobbled some code for a component together based on the Arduino example (AN_275) available from here: http://www.ftdichip.com/Products/ICs/FT800.html
Have a go and see how you get on. If it works ok then I will continue and build this into a full component.
FTDI-FT800.fcfx
(42.69 KiB) Downloaded 465 times
From the looks of the code it is not as clean as the 4D VISI system but may have some other benefits I am not currently aware of.
I've made a bit more progress with the component and this now has the SPI properties built in and ready to export.
Just need to see if it works and if we need to add in any more functions to the component itself.
FTDI-FT800.fcfx
(63.38 KiB) Downloaded 472 times
Don't suppose there is any news on this component yet? I will leave it out the release for now until I know if it's working or not.
John_RSD
Post by John_RSD »
Hi Benj
Thanks for the great effort
As one does I got distracted for quite a bit on another project.
Let me get stuck back into it :-D
John
Many thanks
John
hawk44
Has thanked: 9 times
Been thanked: 6 times
Post by hawk44 »
ok, Does anyone have a schematic of this FT800 hook-up with PIC?
I have downloaded the code for FlowCode, just ordered 3- 33EP256MU806 IC's (My wife is so going to kill me). Plus some other PIC's. :lol:
By the way, March is free shipping. Be sure to enter the code "FreeShipmD" in the code box at checkout. I just couldn't help my self. :oops:
Just ordered the FT800 as well. Been reading alot on this. Looks like fun. :D
Look forward to someone's reply. :P
Thanks, David
ajneal4uk
Has thanked: 1 time
Been thanked: 1 time
Post by ajneal4uk »
Hi;
FTDI have produced this little gem, be nice as a home automation controller.
http://www.ftdichip.com/Support/Documen ... VM800P.pdf
hawk44
Post by hawk44 »
Ahhhhhhhhh....... I purchased the wrong thing.
Thanks for the reply and update. Now I know what is going on. Boy you are right, that is a gem.
But at that price I'm going to have to put it off for a while. I need to finish alot of other projects first anyhow. (grapes thing)
Maybe I can swing it later.
Thanks again for clearing things up for me.
Can't get the data sheet out of my head.....Oh...that is sweet.....
ajneal4uk
Has thanked: 1 time
Post by ajneal4uk »
Arrived from FTDI a 5" arduino compatible display and must say its very nice.
I have used FTDI Eve Screen editor to put a simple gauge on to the display, the editor produces the Arduino code
The Gauge displays 0 up to 100 and then counts back down again.
The simple code makes me think "why do I need a flow code component?"
I'm thinking of including the FTDI library in the supplementary code section and then call the functions from c blocks in flowcode .
#include <EEPROM.h>
#include <SPI.h>
#include <Wire.h>
#include <FT_VM800P43_50.h>
int x = 10;
int y = 0;
char buf[30];
FT800IMPL_SPI FTImpl(FT_CS_PIN,FT_PDN_PIN,FT_INT_PIN);
void setup()
FTImpl.Init(FT_DISPLAY_RESOLUTION);
FTImpl.SetDisplayEnablePin(FT_DISPENABLE_PIN);
FTImpl.SetAudioEnablePin(FT_AUDIOENABLE_PIN);
FTImpl.DisplayOn();
FTImpl.AudioOn();
FTImpl.DLStart();
FTImpl.Finish();
FTImpl.DLStart();
FTImpl.DLEnd();
FTImpl.Finish();
void loop()
if (x > 99) {
y=0;
if (x <1) {
y=1;
memset (buf, 0, sizeof(buf));
snprintf(buf, sizeof(buf)-1, "%d", x);
FTImpl.DLStart();
FTImpl.Cmd_Gauge(357, 127, 88, 0, 4, 8, x, 100);
FTImpl.Cmd_Text(93, 53, 28, 0, buf);
FTImpl.DLEnd();
FTImpl.Finish();
if (y==0) {
x=x-1;
if (y==1) {
x=x+1;
/* end of file */
