I have to interface a device with a connection bus similar to OneWire, but with a communication protocol customized.
Flowcode6 I can use to build the protocol on a wire, or I have to use other software, such as Visual Basic? How can I use Flowcode to build custom protocol on OneWire connection?
custom protocol on onewire
Re: custom protocol on onewire
Using an output or input icon in single bit mode you should be able to bit bang a serial 1-wire style data connection.
This is how the Flowcode 1-wire component was created.
this is the protocol I need to interface. And I do not know how to made it in Flowcode 6
- protocol description.rar
- (18.15 KiB) Downloaded 231 times
Here is something I cobbled together very quickly for you to match the waveform in the pdf. I'm not 100% sure it will work but it should be fairly close and should help to show you the way.
Any questions then please let us know.
I see this is the call function, how can I make the receive in the single wire connection?
I attach the process call and receive I have in the board I attach
- the data sent is organized in bytes.doc
- (29.5 KiB) Downloaded 218 times
protocol single wire
this is the call example, and receive example in the single wire?
this is the complete protocol to interface
- (29.5 KiB) Downloaded 228 times
single wire protocol
this is the call and receive example in the single wire protocol.
how it will be in the flowcode6?
