I am just getting started using FlowCode. I need help on why the 2D Dashboard Panel is not displaying the ruler image and component images. I am attaching to this post a screen image of how it is displayed on my monitor. I believe the black boxes should be numbers and the highlighted rectangular outline should be a 3x4 keypad.
I am using Win7 Pro, 32-bit operating system.
Thank you for your help.
Gary
Need help with 2D Dashboard Panel screen image error
- 2D Dashboard Panel Image.jpg (59.5 KiB) Viewed 2637 times
- Has thanked: 553 times
- Been thanked: 1081 times
Re: Need help with 2D Dashboard Panel screen image error
Try switching the graphics engine.
Open the application settings ('View'->'Global Options', switch to TAB 'Application'). In the right bottom part of the dialog you can choose the 'Graphics engine'. Switch it to the other setting (to hardware if now set to software and vice versa) and restart Flowcode.
― C.S. Lewis
― C.S. Lewis
- Has thanked: 345 times
- Been thanked: 227 times
Or if above doesn't work, try re-installing completely. I've noticed at my current workplace, that for some reason, sometimes the installation doesn't complete fully and needs to be re-installed...
