SPEED CAN-BUS inernal external
Barmaley_GMN
Has thanked: 8 times
Been thanked: 4 times
Re: SPEED CAN-BUS inernal external
Post by Barmaley_GMN »
If I disable macro SetTxData I see
Barmaley_GMN
If I add send for 3 buffers;
#define FCV_0e702_can2__CAN_RTS_TXB3 (135)
after CAN2 init
and
FC_CAN_SPI_CAN_Command_2(FCV_0e702_can2__CAN_RTS_TXB3);
instead of CAN2 sendBuffer macro
I see
Barmaley_GMN
And one more strange moment:
If I use 3buffers at the same time variant I see singular sending on internal CAN1 channel with data from the flowchat for CAN2.
And if there is variant for 3 buffers (with my C) I see singular sending on internal CAN1 channel with data from his buffer TX2
But there is no any sending for CAN1 in flowchat! (I attached it a few posts before).
LeighM
Has thanked: 481 times
Been thanked: 699 times
Post by LeighM »
Thanks for all the data, I have not got my head round it yet :?
Meanwhile, I've just had one thought, in that we did do a bug fix on the CAN component about 10 months ago, relating to the message ID.
I've attached the latest, if you want to drop this into your Flowcode 6 installation /components directory, or compare to what you have.
btw. If you want to make a backup of your previous version, move it to another directory somewhere, don't just rename it.
(Flowcode does not use the filename but scans all components for a unique ID)
Leigh
CAN.fcpx
(23.42 KiB) Downloaded 388 times
Barmaley_GMN
I removed the old CAN.fcpx and placed your to component directory.
Make new hex and... don't see any positive changes:
It steel sends 1 jf 10 frames and 1 from unused component (CAN1)
Barmaley_GMN
There was my mistake about strange sending singular frames from CAN1. I didn't use additional pause for relay (it disconnects CAN1 and CAN2). And time to disconnect was enough for 1 frame.
Sorry.
But losses exists as described.
Barmaley_GMN
THE FC5 works the same.9 loses from 10.
Can I check if the frame is sent and wait for it?
LeighM
Post by LeighM »
Could you give a sketch overview of your CAN networks showing what is connected and where?
Barmaley_GMN
Hi!
Sure!
board.rar
(280.89 KiB) Downloaded 364 times
Barmaley_GMN
As I see I can't use ext.CAN and SPI together or I have to run init. for every component before every operation?
p.s. If I use SPI (FCD_06c41_SPI_Master1__SendChar(129);) I see almost 2 times more frames (546 from 3000).
Now I have checked some variants (spi, can2,can1) All of them have the same timing about 0,005 sec. So, I think the main problem - is a trying to send a frame from TX before it get clear (send previous). But why does my main program want so big delays?...
Barmaley_GMN
The problem seems to be solved.
I have achieved my main goal. It sends all the frames without external delays with check from your macro. And the program does it with the same timings.
It's a little bit strange, but internal CAN (I suppose) has a check from box but external CAN.
And THANK YOU VERY MUCH! :D
P.S. In this case was lived only one buffer (1)
case 0... 0x10...
And of course it's only the main idea. It needs to be remade for exact tasks.
LeighM
Post by LeighM »
Thanks for the updates. Glad to hear you have it working.
Barmaley_GMN
I have the same problem.
This code sends message with the same data
6c1  8  9C 00 00 00 00 00 00
(zero byte can change after restart )
It seems Lo doesn't change.
But if I insert delay for 5 ms it works fine. But delay is too big for Me.
TestCheck.fcfx
(21.6 KiB) Downloaded 315 times
Barmaley_GMN
And if I insert delay 30 us.
I see trace...
Test2.txt
(590.86 KiB) Downloaded 254 times
LeighM
Post by LeighM »
Have you got a receiving CAN device on the bus?
As I recall the CAN transmitter will repeat the message if it does not get an ack.
Could that be the issue?
Barmaley_GMN
Of course! It connected to CAN-hacker.
Listing without delay and checks.
Time   ID     DLC Data                    Comment
04,573 6C1      8 01 01 02 03 00 00 00 00 ASCII:
04,574 6C1      8 01 01 02 03 00 00 00 00 ASCII:
04,576 6C1      8 28 01 02 03 00 00 00 00 ASCII:(
04,577 6C1      8 28 01 02 03 00 00 00 00 ASCII:(
04,578 6C1      8 28 01 02 03 00 00 00 00 ASCII:(
04,580 6C1      8 28 01 02 03 00 00 00 00 ASCII:(
04,581 6C1      8 28 01 02 03 00 00 00 00 ASCII:(
04,582 6C1      8 28 01 02 03 00 00 00 00 ASCII:(
04,583 6C1      8 28 01 02 03 00 00 00 00 ASCII:(
04,585 6C1      8 AE 01 02 03 00 00 00 00 ASCII:
04,586 6C1      8 AE 01 02 03 00 00 00 00 ASCII:
04,587 6C1      8 AE 01 02 03 00 00 00 00 ASCII:
04,589 6C1      8 AE 01 02 03 00 00 00 00 ASCII:
04,590 6C1      8 AE 01 02 03 00 00 00 00 ASCII:
04,591 6C1      8 AE 01 02 03 00 00 00 00 ASCII:
04,592 6C1      8 AE 01 02 03 00 00 00 00 ASCII:
04,594 6C1      8 AE 01 02 03 00 00 00 00 ASCII:
04,595 6C1      8 AE 01 02 03 00 00 00 00 ASCII:
04,596 6C1      8 AE 01 02 03 00 00 00 00 ASCII:
04,598 6C1      8 AE 01 02 03 00 00 00 00 ASCII:
04,599 6C1      8 AE 01 02 03 00 00 00 00 ASCII:
04,600 6C1      8 AE 01 02 03 00 00 00 00 ASCII:
04,602 6C1      8 AE 01 02 03 00 00 00 00 ASCII:
04,603 6C1      8 AE 01 02 03 00 00 00 00 ASCII:
04,604 6C1      8 AE 01 02 03 00 00 00 00 ASCII:
04,605 6C1      8 AE 01 02 03 00 00 00 00 ASCII:
Barmaley_GMN
It seems like external channel doesn't set TX_Data and just sends buffer.
When I connect both CAN channel I see that
43,562 001      8 01 01 02 03 04 05 06 07 ASCII:
43,563 001      8 01 01 01 03 04 05 06 07 ASCII:
43,564 001      8 02 01 02 03 04 05 06 07 ASCII:
43,566 001      8 01 01 01 03 04 05 06 07 ASCII:
43,567 001      8 03 01 02 03 04 05 06 07 ASCII:
43,568 001      8 01 01 01 03 04 05 06 07 ASCII:
43,569 001      8 04 01 02 03 04 05 06 07 ASCII:
43,571 001      8 01 01 01 03 04 05 06 07 ASCII:
43,572 001      8 05 01 02 03 04 05 06 07 ASCII:
43,573 001      8 01 01 01 03 04 05 06 07 ASCII:
43,575 001      8 06 01 02 03 04 05 06 07 ASCII:
43,576 001      8 01 01 01 03 04 05 06 07 ASCII:
43,577 001      8 07 01 02 03 04 05 06 07 ASCII:
43,578 001      8 01 01 01 03 04 05 06 07 ASCII:
43,580 001      8 08 01 02 03 04 05 06 07 ASCII:
43,581 001      8 01 01 01 03 04 05 06 07 ASCII:
43,582 001      8 09 01 02 03 04 05 06 07 ASCII:
43,583 001      8 01 01 01 03 04 05 06 07 ASCII:
43,585 001      8 0A 01 02 03 04 05 06 07 ASCII:
43,586 001      8 01 01 01 03 04 05 06 07 ASCII:
43,587 001      8 0B 01 02 03 04 05 06 07 ASCII:
43,589 001      8 01 01 01 03 04 05 06 07 ASCII:
43,590 001      8 0C 01 02 03 04 05 06 07 ASCII:
43,591 001      8 01 01 01 03 04 05 06 07 ASCII:
43,592 001      8 0D 01 02 03 04 05 06 07 ASCII:
43,594 001      8 01 01 01 03 04 05 06 07 ASCII:
43,595 001      8 0E 01 02 03 04 05 06 07 ASCII:
43,596 001      8 01 01 01 03 04 05 06 07 ASCII:
43,598 001      8 0F 01 02 03 04 05 06 07 ASCII:
43,599 001      8 01 01 01 03 04 05 06 07 ASCII:
43,600 001      8 10 01 02 03 04 05 06 07 ASCII:
43,601 001      8 01 01 01 03 04 05 06 07 ASCII:
43,603 001      8 11 01 02 03 04 05 06 07 ASCII:
43,604 001      8 01 01 01 03 04 05 06 07 ASCII:
43,605 001      8 12 01 02 03 04 05 06 07 ASCII:
43,607 001      8 01 01 01 03 04 05 06 07 ASCII:
43,608 001      8 13 01 02 03 04 05 06 07 ASCII:
43,609 001      8 01 01 01 03 04 05 06 07 ASCII:
43,610 001      8 14 01 02 03 04 05 06 07 ASCII:
43,612 001      8 01 01 01 03 04 05 06 07 ASCII:
43,613 001      8 15 01 02 03 04 05 06 07 ASCII:
43,614 001      8 01 01 01 03 04 05 06 07 ASCII:
43,616 001      8 16 01 02 03 04 05 06 07 ASCII:
43,617 001      8 01 01 01 03 04 05 06 07 ASCII:
43,618 001      8 17 01 02 03 04 05 06 07 ASCII:
43,619 001      8 01 01 01 03 04 05 06 07 ASCII:
43,621 001      8 18 01 02 03 04 05 06 07 ASCII:
43,622 001      8 01 01 01 03 04 05 06 07 ASCII:
43,623 001      8 19 01 02 03 04 05 06 07 ASCII:
43,625 001      8 01 01 01 03 04 05 06 07 ASCII:
43,626 001      8 1A 01 02 03 04 05 06 07 ASCII:
43,627 001      8 01 01 01 03 04 05 06 07 ASCII:
43,629 001      8 1B 01 02 03 04 05 06 07 ASCII:
43,630 001      8 01 01 01 03 04 05 06 07 ASCII:
43,631 001      8 1C 01 02 03 04 05 06 07 ASCII:
43,632 001      8 01 01 01 03 04 05 06 07 ASCII:
43,634 001      8 1D 01 02 03 04 05 06 07 ASCII:
43,635 001      8 01 01 01 03 04 05 06 07 ASCII:
43,636 001      8 1E 01 02 03 04 05 06 07 ASCII:
43,637 001      8 01 01 01 03 04 05 06 07 ASCII:
43,639 001      8 1F 01 02 03 04 05 06 07 ASCII:
43,640 001      8 01 01 01 03 04 05 06 07 ASCII:
43,641 001      8 20 01 02 03 04 05 06 07 ASCII:
43,643 001      8 01 01 01 03 04 05 06 07 ASCII:
43,644 001      8 21 01 02 03 04 05 06 07 ASCII:!
43,645 001      8 01 01 01 03 04 05 06 07 ASCII:
43,646 001      8 22 01 02 03 04 05 06 07 ASCII:"
43,648 001      8 01 01 01 03 04 05 06 07 ASCII:
43,649 001      8 23 01 02 03 04 05 06 07 ASCII:#
43,650 001      8 01 01 01 03 04 05 06 07 ASCII:
43,652 001      8 24 01 02 03 04 05 06 07 ASCII:$
43,653 001      8 01 01 01 03 04 05 06 07 ASCII:
43,654 001      8 25 01 02 03 04 05 06 07 ASCII:%
43,655 001      8 01 01 01 03 04 05 06 07 ASCII:
43,657 001      8 26 01 02 03 04 05 06 07 ASCII:&
43,658 001      8 01 01 01 03 04 05 06 07 ASCII:
43,659 001      8 27 01 02 03 04 05 06 07 ASCII:'
43,661 001      8 01 01 01 03 04 05 06 07 ASCII:
43,662 001      8 28 01 02 03 04 05 06 07 ASCII:(
43,663 001      8 01 01 01 03 04 05 06 07 ASCII:
43,664 001      8 29 01 02 03 04 05 06 07 ASCII:)
43,666 001      8 01 01 01 03 04 05 06 07 ASCII:
43,667 001      8 2A 01 02 03 04 05 06 07 ASCII:*
43,668 001      8 01 01 01 03 04 05 06 07 ASCII:
43,670 001      8 2B 01 02 03 04 05 06 07 ASCII:+
43,671 001      8 01 01 01 03 04 05 06 07 ASCII:
43,672 001      8 2C 01 02 03 04 05 06 07 ASCII:,
43,673 001      8 01 01 01 03 04 05 06 07 ASCII:
43,675 001      8 2D 01 02 03 04 05 06 07 ASCII:-
43,676 001      8 01 01 01 03 04 05 06 07 ASCII:
43,677 001      8 2E 01 02 03 04 05 06 07 ASCII:.
43,679 001      8 01 01 01 03 04 05 06 07 ASCII:
43,680 001      8 2F 01 02 03 04 05 06 07 ASCII:/
43,681 001      8 01 01 01 03 04 05 06 07 ASCII:
43,682 001      8 30 01 02 03 04 05 06 07 ASCII:0
43,684 001      8 01 01 01 03 04 05 06 07 ASCII:
43,685 001      8 31 01 02 03 04 05 06 07 ASCII:1
43,686 001      8 01 01 01 03 04 05 06 07 ASCII:
43,688 001      8 32 01 02 03 04 05 06 07 ASCII:2
43,689 001      8 01 01 01 03 04 05 06 07 ASCII:
43,690 001      8 33 01 02 03 04 05 06 07 ASCII:3
43,691 001      8 01 01 01 03 04 05 06 07 ASCII:
43,693 001      8 34 01 02 03 04 05 06 07 ASCII:4
43,694 001      8 01 01 01 03 04 05 06 07 ASCII:
43,695 001      8 35 01 02 03 04 05 06 07 ASCII:5
43,697 001      8 01 01 01 03 04 05 06 07 ASCII:
43,698 001      8 36 01 02 03 04 05 06 07 ASCII:6
43,699 001      8 01 01 01 03 04 05 06 07 ASCII:
43,700 001      8 37 01 02 03 04 05 06 07 ASCII:7
43,702 001      8 01 01 01 03 04 05 06 07 ASCII:
43,703 001      8 38 01 02 03 04 05 06 07 ASCII:8
43,704 001      8 01 01 01 03 04 05 06 07 ASCII:
43,706 001      8 39 01 02 03 04 05 06 07 ASCII:9
43,707 001      8 01 01 01 03 04 05 06 07 ASCII:
43,708 001      8 3A 01 02 03 04 05 06 07 ASCII::
43,709 001      8 01 01 01 03 04 05 06 07 ASCII:
43,711 001      8 3B 01 02 03 04 05 06 07 ASCII:;
43,712 001      8 01 01 01 03 04 05 06 07 ASCII:
43,713 001      8 3C 01 02 03 04 05 06 07 ASCII:<
43,715 001      8 01 01 01 03 04 05 06 07 ASCII:
43,716 001      8 3D 01 02 03 04 05 06 07 ASCII:=
43,717 001      8 01 01 01 03 04 05 06 07 ASCII:
43,718 001      8 3E 01 02 03 04 05 06 07 ASCII:>
43,720 001      8 01 01 01 03 04 05 06 07 ASCII:
43,721 001      8 3F 01 02 03 04 05 06 07 ASCII:?
43,722 001      8 01 01 01 03 04 05 06 07 ASCII:
43,724 001      8 40 01 02 03 04 05 06 07 ASCII:@
43,725 001      8 01 01 01 03 04 05 06 07 ASCII:
43,726 001      8 41 01 02 03 04 05 06 07 ASCII:A
43,727 001      8 01 01 01 03 04 05 06 07 ASCII:
43,729 001      8 42 01 02 03 04 05 06 07 ASCII:B
43,730 001      8 01 01 01 03 04 05 06 07 ASCII:
43,731 001      8 43 01 02 03 04 05 06 07 ASCII:C
43,733 001      8 01 01 01 03 04 05 06 07 ASCII:
43,734 001      8 44 01 02 03 04 05 06 07 ASCII:D
43,735 001      8 01 01 01 03 04 05 06 07 ASCII:
43,736 001      8 45 01 02 03 04 05 06 07 ASCII:E
43,738 001      8 01 01 01 03 04 05 06 07 ASCII:
43,739 001      8 46 01 02 03 04 05 06 07 ASCII:F
43,740 001      8 01 01 01 03 04 05 06 07 ASCII:
43,742 001      8 47 01 02 03 04 05 06 07 ASCII:G
43,743 001      8 01 01 01 03 04 05 06 07 ASCII:
43,744 001      8 48 01 02 03 04 05 06 07 ASCII:H
43,745 001      8 01 01 01 03 04 05 06 07 ASCII:
43,747 001      8 49 01 02 03 04 05 06 07 ASCII:I
43,748 001      8 01 01 01 03 04 05 06 07 ASCII:
43,749 001      8 4A 01 02 03 04 05 06 07 ASCII:J
43,751 001      8 01 01 01 03 04 05 06 07 ASCII:
43,752 001      8 4B 01 02 03 04 05 06 07 ASCII:K
43,753 001      8 01 01 01 03 04 05 06 07 ASCII:
43,754 001      8 4C 01 02 03 04 05 06 07 ASCII:L
43,756 001      8 01 01 01 03 04 05 06 07 ASCII:
43,757 001      8 4D 01 02 03 04 05 06 07 ASCII:M
43,758 001      8 01 01 01 03 04 05 06 07 ASCII:
43,759 001      8 4E 01 02 03 04 05 06 07 ASCII:N
43,761 001      8 01 01 01 03 04 05 06 07 ASCII:
43,762 001      8 4F 01 02 03 04 05 06 07 ASCII:O
43,763 001      8 01 01 01 03 04 05 06 07 ASCII:
43,765 001      8 50 01 02 03 04 05 06 07 ASCII:P
43,766 001      8 01 01 01 03 04 05 06 07 ASCII:
43,767 001      8 51 01 02 03 04 05 06 07 ASCII:Q
43,768 001      8 01 01 01 03 04 05 06 07 ASCII:
43,770 001      8 52 01 02 03 04 05 06 07 ASCII:R
43,771 001      8 01 01 01 03 04 05 06 07 ASCII:
43,772 001      8 53 01 02 03 04 05 06 07 ASCII:S
43,774 001      8 01 01 01 03 04 05 06 07 ASCII:
43,775 001      8 54 01 02 03 04 05 06 07 ASCII:T
43,776 001      8 01 01 01 03 04 05 06 07 ASCII:
43,777 001      8 55 01 02 03 04 05 06 07 ASCII:U
43,779 001      8 01 01 01 03 04 05 06 07 ASCII:
43,780 001      8 56 01 02 03 04 05 06 07 ASCII:V
43,781 001      8 01 01 01 03 04 05 06 07 ASCII:
43,782 001      8 57 01 02 03 04 05 06 07 ASCII:W
43,784 001      8 01 01 01 03 04 05 06 07 ASCII:
43,785 001      8 58 01 02 03 04 05 06 07 ASCII:X
43,786 001      8 01 01 01 03 04 05 06 07 ASCII:
43,788 001      8 59 01 02 03 04 05 06 07 ASCII:Y
43,789 001      8 01 01 01 03 04 05 06 07 ASCII:
43,790 001      8 5A 01 02 03 04 05 06 07 ASCII:Z
43,791 001      8 01 01 01 03 04 05 06 07 ASCII:
43,793 001      8 5B 01 02 03 04 05 06 07 ASCII:[
43,794 001      8 01 01 01 03 04 05 06 07 ASCII:
43,795 001      8 5C 01 02 03 04 05 06 07 ASCII:\
43,797 001      8 01 01 01 03 04 05 06 07 ASCII:
43,798 001      8 5D 01 02 03 04 05 06 07 ASCII:]
43,799 001      8 01 01 01 03 04 05 06 07 ASCII:
43,800 001      8 5E 01 02 03 04 05 06 07 ASCII:^
43,802 001      8 01 01 01 03 04 05 06 07 ASCII:
43,803 001      8 5F 01 02 03 04 05 06 07 ASCII:_
43,804 001      8 01 01 01 03 04 05 06 07 ASCII:
43,806 001      8 60 01 02 03 04 05 06 07 ASCII:`
43,807 001      8 01 01 01 03 04 05 06 07 ASCII:
43,808 001      8 61 01 02 03 04 05 06 07 ASCII:a
43,809 001      8 01 01 01 03 04 05 06 07 ASCII:
43,811 001      8 62 01 02 03 04 05 06 07 ASCII:b
43,812 001      8 01 01 01 03 04 05 06 07 ASCII:
43,813 001      8 63 01 02 03 04 05 06 07 ASCII:c
43,814 001      8 01 01 01 03 04 05 06 07 ASCII:
43,816 001      8 64 01 02 03 04 05 06 07 ASCII:d
43,817 001      8 01 01 01 03 04 05 06 07 ASCII:
43,818 001      8 65 01 02 03 04 05 06 07 ASCII:e
43,820 001      8 01 01 01 03 04 05 06 07 ASCII:
43,821 001      8 66 01 02 03 04 05 06 07 ASCII:f
43,822 001      8 01 01 01 03 04 05 06 07 ASCII:
43,823 001      8 67 01 02 03 04 05 06 07 ASCII:g
43,825 001      8 01 01 01 03 04 05 06 07 ASCII:
43,826 001      8 68 01 02 03 04 05 06 07 ASCII:h
43,827 001      8 01 01 01 03 04 05 06 07 ASCII:
43,829 001      8 69 01 02 03 04 05 06 07 ASCII:i
43,830 001      8 01 01 01 03 04 05 06 07 ASCII:
43,831 001      8 6A 01 02 03 04 05 06 07 ASCII:j
43,832 001      8 01 01 01 03 04 05 06 07 ASCII:
43,834 001      8 6B 01 02 03 04 05 06 07 ASCII:k
43,835 001      8 01 01 01 03 04 05 06 07 ASCII:
43,836 001      8 6C 01 02 03 04 05 06 07 ASCII:l
43,838 001      8 01 01 01 03 04 05 06 07 ASCII:
43,839 001      8 6D 01 02 03 04 05 06 07 ASCII:m
43,840 001      8 01 01 01 03 04 05 06 07 ASCII:
43,841 001      8 6E 01 02 03 04 05 06 07 ASCII:n
43,843 001      8 01 01 01 03 04 05 06 07 ASCII:
43,844 001      8 6F 01 02 03 04 05 06 07 ASCII:o
43,845 001      8 01 01 01 03 04 05 06 07 ASCII:
43,846 001      8 70 01 02 03 04 05 06 07 ASCII:p
43,848 001      8 01 01 01 03 04 05 06 07 ASCII:
43,849 001      8 71 01 02 03 04 05 06 07 ASCII:q
43,850 001      8 01 01 01 03 04 05 06 07 ASCII:
43,852 001      8 72 01 02 03 04 05 06 07 ASCII:r
43,853 001      8 01 01 01 03 04 05 06 07 ASCII:
43,854 001      8 73 01 02 03 04 05 06 07 ASCII:s
43,855 001      8 01 01 01 03 04 05 06 07 ASCII:
43,857 001      8 74 01 02 03 04 05 06 07 ASCII:t
43,858 001      8 01 01 01 03 04 05 06 07 ASCII:
43,859 001      8 75 01 02 03 04 05 06 07 ASCII:u
43,861 001      8 01 01 01 03 04 05 06 07 ASCII:
43,862 001      8 76 01 02 03 04 05 06 07 ASCII:v
43,863 001      8 01 01 01 03 04 05 06 07 ASCII:
43,864 001      8 77 01 02 03 04 05 06 07 ASCII:w
43,866 001      8 01 01 01 03 04 05 06 07 ASCII:
43,867 001      8 78 01 02 03 04 05 06 07 ASCII:x
43,868 001      8 01 01 01 03 04 05 06 07 ASCII:
43,870 001      8 79 01 02 03 04 05 06 07 ASCII:y
43,871 001      8 01 01 01 03 04 05 06 07 ASCII:
43,872 001      8 7A 01 02 03 04 05 06 07 ASCII:z
43,873 001      8 01 01 01 03 04 05 06 07 ASCII:
43,875 001      8 7B 01 02 03 04 05 06 07 ASCII:{
43,876 001      8 01 01 01 03 04 05 06 07 ASCII:
43,877 001      8 7C 01 02 03 04 05 06 07 ASCII:|
43,879 001      8 01 01 01 03 04 05 06 07 ASCII:
43,880 001      8 7D 01 02 03 04 05 06 07 ASCII:}
43,881 001      8 01 01 01 03 04 05 06 07 ASCII:
43,882 001      8 7E 01 02 03 04 05 06 07 ASCII:~
43,884 001      8 01 01 01 03 04 05 06 07 ASCII:
43,885 001      8 7F 01 02 03 04 05 06 07 ASCII:
43,886 001      8 01 01 01 03 04 05 06 07 ASCII:
43,887 001      8 80 01 02 03 04 05 06 07 ASCII:
43,889 001      8 01 01 01 03 04 05 06 07 ASCII:
43,890 001      8 81 01 02 03 04 05 06 07 ASCII:
43,891 001      8 01 01 01 03 04 05 06 07 ASCII:
43,893 001      8 82 01 02 03 04 05 06 07 ASCII:
43,894 001      8 01 01 01 03 04 05 06 07 ASCII:
43,895 001      8 83 01 02 03 04 05 06 07 ASCII:
43,896 001      8 01 01 01 03 04 05 06 07 ASCII:
43,898 001      8 84 01 02 03 04 05 06 07 ASCII:
43,899 001      8 01 01 01 03 04 05 06 07 ASCII:
43,900 001      8 85 01 02 03 04 05 06 07 ASCII:
43,902 001      8 01 01 01 03 04 05 06 07 ASCII:
43,903 001      8 86 01 02 03 04 05 06 07 ASCII:
43,904 001      8 01 01 01 03 04 05 06 07 ASCII:
43,905 001      8 87 01 02 03 04 05 06 07 ASCII:
43,907 001      8 01 01 01 03 04 05 06 07 ASCII:
43,908 001      8 88 01 02 03 04 05 06 07 ASCII:
43,909 001      8 01 01 01 03 04 05 06 07 ASCII:
43,911 001      8 89 01 02 03 04 05 06 07 ASCII:
43,912 001      8 01 01 01 03 04 05 06 07 ASCII:
43,913 001      8 8A 01 02 03 04 05 06 07 ASCII:
43,914 001      8 01 01 01 03 04 05 06 07 ASCII:
43,916 001      8 8B 01 02 03 04 05 06 07 ASCII:
43,917 001      8 01 01 01 03 04 05 06 07 ASCII:
43,918 001      8 8C 01 02 03 04 05 06 07 ASCII:
43,920 001      8 01 01 01 03 04 05 06 07 ASCII:
43,921 001      8 8D 01 02 03 04 05 06 07 ASCII:
43,922 001      8 01 01 01 03 04 05 06 07 ASCII:
43,923 001      8 8E 01 02 03 04 05 06 07 ASCII:
43,925 001      8 01 01 01 03 04 05 06 07 ASCII:
43,926 001      8 8F 01 02 03 04 05 06 07 ASCII:
43,927 001      8 01 01 01 03 04 05 06 07 ASCII:
43,928 001      8 90 01 02 03 04 05 06 07 ASCII:
43,930 001      8 01 01 01 03 04 05 06 07 ASCII:
43,931 001      8 91 01 02 03 04 05 06 07 ASCII:
43,932 001      8 01 01 01 03 04 05 06 07 ASCII:
43,934 001      8 92 01 02 03 04 05 06 07 ASCII:
43,935 001      8 01 01 01 03 04 05 06 07 ASCII:
43,936 001      8 93 01 02 03 04 05 06 07 ASCII:
43,937 001      8 01 01 01 03 04 05 06 07 ASCII:
43,939 001      8 94 01 02 03 04 05 06 07 ASCII:
43,940 001      8 01 01 01 03 04 05 06 07 ASCII:
43,941 001      8 95 01 02 03 04 05 06 07 ASCII:
43,943 001      8 01 01 01 03 04 05 06 07 ASCII:
43,944 001      8 96 01 02 03 04 05 06 07 ASCII:
43,945 001      8 01 01 01 03 04 05 06 07 ASCII:
43,946 001      8 97 01 02 03 04 05 06 07 ASCII:
43,948 001      8 01 01 01 03 04 05 06 07 ASCII:
43,949 001      8 98 01 02 03 04 05 06 07 ASCII:
43,950 001      8 01 01 01 03 04 05 06 07 ASCII:
43,951 001      8 99 01 02 03 04 05 06 07 ASCII:
43,953 001      8 01 01 01 03 04 05 06 07 ASCII:
43,954 001      8 9A 01 02 03 04 05 06 07 ASCII:
43,955 001      8 01 01 01 03 04 05 06 07 ASCII:
43,957 001      8 9B 01 02 03 04 05 06 07 ASCII:
43,958 001      8 01 01 01 03 04 05 06 07 ASCII:
43,959 001      8 9C 01 02 03 04 05 06 07 ASCII:
43,960 001      8 01 01 01 03 04 05 06 07 ASCII:
43,962 001      8 9D 01 02 03 04 05 06 07 ASCII:
43,963 001      8 01 01 01 03 04 05 06 07 ASCII:
43,964 001      8 9E 01 02 03 04 05 06 07 ASCII:
43,966 001      8 01 01 01 03 04 05 06 07 ASCII:
43,967 001      8 9F 01 02 03 04 05 06 07 ASCII:
43,968 001      8 01 01 01 03 04 05 06 07 ASCII:
43,969 001      8 A0 01 02 03 04 05 06 07 ASCII:
43,971 001      8 01 01 01 03 04 05 06 07 ASCII:
43,972 001      8 A1 01 02 03 04 05 06 07 ASCII:
43,973 001      8 01 01 01 03 04 05 06 07 ASCII:
43,975 001      8 A2 01 02 03 04 05 06 07 ASCII:
43,976 001      8 01 01 01 03 04 05 06 07 ASCII:
43,977 001      8 A3 01 02 03 04 05 06 07 ASCII:
43,978 001      8 01 01 01 03 04 05 06 07 ASCII:
43,980 001      8 A4 01 02 03 04 05 06 07 ASCII:
43,981 001      8 01 01 01 03 04 05 06 07 ASCII:
43,982 001      8 A5 01 02 03 04 05 06 07 ASCII:
43,983 001      8 01 01 01 03 04 05 06 07 ASCII:
43,985 001      8 A6 01 02 03 04 05 06 07 ASCII:
43,986 001      8 01 01 01 03 04 05 06 07 ASCII:
43,987 001      8 A7 01 02 03 04 05 06 07 ASCII:
43,989 001      8 01 01 01 03 04 05 06 07 ASCII:
43,990 001      8 A8 01 02 03 04 05 06 07 ASCII:
43,991 001      8 01 01 01 03 04 05 06 07 ASCII:
43,992 001      8 A9 01 02 03 04 05 06 07 ASCII:
43,994 001      8 01 01 01 03 04 05 06 07 ASCII:
43,995 001      8 AA 01 02 03 04 05 06 07 ASCII:
43,996 001      8 01 01 01 03 04 05 06 07 ASCII:
43,998 001      8 AB 01 02 03 04 05 06 07 ASCII:
43,999 001      8 01 01 01 03 04 05 06 07 ASCII:
44,000 001      8 AC 01 02 03 04 05 06 07 ASCII:
44,001 001      8 01 01 01 03 04 05 06 07 ASCII:
44,003 001      8 AD 01 02 03 04 05 06 07 ASCII:
44,004 001      8 01 01 01 03 04 05 06 07 ASCII:
44,005 001      8 AE 01 02 03 04 05 06 07 ASCII:
44,007 001      8 01 01 01 03 04 05 06 07 ASCII:
44,008 001      8 AF 01 02 03 04 05 06 07 ASCII:
44,009 001      8 01 01 01 03 04 05 06 07 ASCII:
44,010 001      8 B0 01 02 03 04 05 06 07 ASCII:
44,012 001      8 01 01 01 03 04 05 06 07 ASCII:
44,013 001      8 B1 01 02 03 04 05 06 07 ASCII:
44,014 001      8 01 01 01 03 04 05 06 07 ASCII:
44,015 001      8 B2 01 02 03 04 05 06 07 ASCII:
44,017 001      8 01 01 01 03 04 05 06 07 ASCII:
44,018 001      8 B3 01 02 03 04 05 06 07 ASCII:
44,019 001      8 01 01 01 03 04 05 06 07 ASCII:
44,021 001      8 B4 01 02 03 04 05 06 07 ASCII:
44,022 001      8 01 01 01 03 04 05 06 07 ASCII:
44,023 001      8 B5 01 02 03 04 05 06 07 ASCII:
44,024 001      8 01 01 01 03 04 05 06 07 ASCII:
44,026 001      8 B6 01 02 03 04 05 06 07 ASCII:
44,027 001      8 01 01 01 03 04 05 06 07 ASCII:
44,028 001      8 B7 01 02 03 04 05 06 07 ASCII:
44,030 001      8 01 01 01 03 04 05 06 07 ASCII:
44,031 001      8 B8 01 02 03 04 05 06 07 ASCII:
44,032 001      8 01 01 01 03 04 05 06 07 ASCII:
44,033 001      8 B9 01 02 03 04 05 06 07 ASCII:
44,035 001      8 01 01 01 03 04 05 06 07 ASCII:
44,036 001      8 BA 01 02 03 04 05 06 07 ASCII:
44,037 001      8 01 01 01 03 04 05 06 07 ASCII:
44,039 001      8 BB 01 02 03 04 05 06 07 ASCII:
44,040 001      8 01 01 01 03 04 05 06 07 ASCII:
44,041 001      8 BC 01 02 03 04 05 06 07 ASCII:
44,042 001      8 01 01 01 03 04 05 06 07 ASCII:
44,044 001      8 BD 01 02 03 04 05 06 07 ASCII:
44,045 001      8 01 01 01 03 04 05 06 07 ASCII:
44,046 001      8 BE 01 02 03 04 05 06 07 ASCII:
44,047 001      8 01 01 01 03 04 05 06 07 ASCII:
44,049 001      8 BF 01 02 03 04 05 06 07 ASCII:
44,050 001      8 01 01 01 03 04 05 06 07 ASCII:
44,051 001      8 C0 01 02 03 04 05 06 07 ASCII:
44,053 001      8 01 01 01 03 04 05 06 07 ASCII:
44,054 001      8 C1 01 02 03 04 05 06 07 ASCII:
44,055 001      8 01 01 01 03 04 05 06 07 ASCII:
44,056 001      8 C2 01 02 03 04 05 06 07 ASCII:
44,058 001      8 01 01 01 03 04 05 06 07 ASCII:
44,059 001      8 C3 01 02 03 04 05 06 07 ASCII:
44,060 001      8 01 01 01 03 04 05 06 07 ASCII:
44,062 001      8 C4 01 02 03 04 05 06 07 ASCII:
44,063 001      8 01 01 01 03 04 05 06 07 ASCII:
44,064 001      8 C5 01 02 03 04 05 06 07 ASCII:
44,065 001      8 01 01 01 03 04 05 06 07 ASCII:
44,067 001      8 C6 01 02 03 04 05 06 07 ASCII:
44,068 001      8 01 01 01 03 04 05 06 07 ASCII:
44,069 001      8 C7 01 02 03 04 05 06 07 ASCII:
44,071 001      8 01 01 01 03 04 05 06 07 ASCII:
44,072 001      8 C8 01 02 03 04 05 06 07 ASCII:
44,073 001      8 01 01 01 03 04 05 06 07 ASCII:
44,074 001      8 C9 01 02 03 04 05 06 07 ASCII:
44,076 001      8 01 01 01 03 04 05 06 07 ASCII:
44,077 001      8 CA 01 02 03 04 05 06 07 ASCII:
44,078 001      8 01 01 01 03 04 05 06 07 ASCII:
44,079 001      8 CB 01 02 03 04 05 06 07 ASCII:
44,081 001      8 01 01 01 03 04 05 06 07 ASCII:
44,082 001      8 CC 01 02 03 04 05 06 07 ASCII:
44,083 001      8 01 01 01 03 04 05 06 07 ASCII:
44,085 001      8 CD 01 02 03 04 05 06 07 ASCII:
44,086 001      8 01 01 01 03 04 05 06 07 ASCII:
44,087 001      8 CE 01 02 03 04 05 06 07 ASCII:
44,088 001      8 01 01 01 03 04 05 06 07 ASCII:
44,090 001      8 CF 01 02 03 04 05 06 07 ASCII:
44,091 001      8 01 01 01 03 04 05 06 07 ASCII:
44,092 001      8 D0 01 02 03 04 05 06 07 ASCII:
44,094 001      8 01 01 01 03 04 05 06 07 ASCII:
44,095 001      8 D1 01 02 03 04 05 06 07 ASCII:
44,096 001      8 01 01 01 03 04 05 06 07 ASCII:
44,097 001      8 D2 01 02 03 04 05 06 07 ASCII:
44,099 001      8 01 01 01 03 04 05 06 07 ASCII:
44,100 001      8 D3 01 02 03 04 05 06 07 ASCII:
44,101 001      8 01 01 01 03 04 05 06 07 ASCII:
44,103 001      8 D4 01 02 03 04 05 06 07 ASCII:
44,104 001      8 01 01 01 03 04 05 06 07 ASCII:
44,105 001      8 D5 01 02 03 04 05 06 07 ASCII:
44,106 001      8 01 01 01 03 04 05 06 07 ASCII:
44,108 001      8 D6 01 02 03 04 05 06 07 ASCII:
44,109 001      8 01 01 01 03 04 05 06 07 ASCII:
44,110 001      8 D7 01 02 03 04 05 06 07 ASCII:
44,111 001      8 01 01 01 03 04 05 06 07 ASCII:
44,113 001      8 D8 01 02 03 04 05 06 07 ASCII:
44,114 001      8 01 01 01 03 04 05 06 07 ASCII:
44,115 001      8 D9 01 02 03 04 05 06 07 ASCII:
44,117 001      8 01 01 01 03 04 05 06 07 ASCII:
44,118 001      8 DA 01 02 03 04 05 06 07 ASCII:
44,119 001      8 01 01 01 03 04 05 06 07 ASCII:
44,120 001      8 DB 01 02 03 04 05 06 07 ASCII:
44,122 001      8 01 01 01 03 04 05 06 07 ASCII:
44,123 001      8 DC 01 02 03 04 05 06 07 ASCII:
44,124 001      8 01 01 01 03 04 05 06 07 ASCII:
44,126 001      8 DD 01 02 03 04 05 06 07 ASCII:
44,127 001      8 01 01 01 03 04 05 06 07 ASCII:
44,128 001      8 DE 01 02 03 04 05 06 07 ASCII:
44,129 001      8 01 01 01 03 04 05 06 07 ASCII:
44,131 001      8 DF 01 02 03 04 05 06 07 ASCII:
44,132 001      8 01 01 01 03 04 05 06 07 ASCII:
44,133 001      8 E0 01 02 03 04 05 06 07 ASCII:
44,135 001      8 01 01 01 03 04 05 06 07 ASCII:
44,136 001      8 E1 01 02 03 04 05 06 07 ASCII:
44,137 001      8 01 01 01 03 04 05 06 07 ASCII:
44,138 001      8 E2 01 02 03 04 05 06 07 ASCII:
44,140 001      8 01 01 01 03 04 05 06 07 ASCII:
44,141 001      8 E3 01 02 03 04 05 06 07 ASCII:
44,142 001      8 01 01 01 03 04 05 06 07 ASCII:
44,143 001      8 E4 01 02 03 04 05 06 07 ASCII:
44,145 001      8 01 01 01 03 04 05 06 07 ASCII:
44,146 001      8 E5 01 02 03 04 05 06 07 ASCII:
44,147 001      8 01 01 01 03 04 05 06 07 ASCII:
44,149 001      8 E6 01 02 03 04 05 06 07 ASCII:
44,150 001      8 01 01 01 03 04 05 06 07 ASCII:
44,151 001      8 E7 01 02 03 04 05 06 07 ASCII:
44,152 001      8 01 01 01 03 04 05 06 07 ASCII:
44,154 001      8 E8 01 02 03 04 05 06 07 ASCII:
44,155 001      8 01 01 01 03 04 05 06 07 ASCII:
44,156 001      8 E9 01 02 03 04 05 06 07 ASCII:
44,158 001      8 01 01 01 03 04 05 06 07 ASCII:
44,159 001      8 EA 01 02 03 04 05 06 07 ASCII:
44,160 001      8 01 01 01 03 04 05 06 07 ASCII:
44,161 001      8 EB 01 02 03 04 05 06 07 ASCII:
44,163 001      8 01 01 01 03 04 05 06 07 ASCII:
44,164 001      8 EC 01 02 03 04 05 06 07 ASCII:
44,165 001      8 01 01 01 03 04 05 06 07 ASCII:
44,167 001      8 ED 01 02 03 04 05 06 07 ASCII:
44,168 001      8 01 01 01 03 04 05 06 07 ASCII:
44,169 001      8 EE 01 02 03 04 05 06 07 ASCII:
44,170 001      8 01 01 01 03 04 05 06 07 ASCII:
44,172 001      8 EF 01 02 03 04 05 06 07 ASCII:
44,173 001      8 01 01 01 03 04 05 06 07 ASCII:
44,174 001      8 F0 01 02 03 04 05 06 07 ASCII:
44,175 001      8 01 01 01 03 04 05 06 07 ASCII:
44,177 001      8 F1 01 02 03 04 05 06 07 ASCII:
44,178 001      8 01 01 01 03 04 05 06 07 ASCII:
44,179 001      8 F2 01 02 03 04 05 06 07 ASCII:
44,181 001      8 01 01 01 03 04 05 06 07 ASCII:
44,182 001      8 F3 01 02 03 04 05 06 07 ASCII:
44,183 001      8 01 01 01 03 04 05 06 07 ASCII:
44,184 001      8 F4 01 02 03 04 05 06 07 ASCII:
44,186 001      8 01 01 01 03 04 05 06 07 ASCII:
44,187 001      8 F5 01 02 03 04 05 06 07 ASCII:
44,188 001      8 01 01 01 03 04 05 06 07 ASCII:
44,190 001      8 F6 01 02 03 04 05 06 07 ASCII:
44,191 001      8 01 01 01 03 04 05 06 07 ASCII:
44,192 001      8 F7 01 02 03 04 05 06 07 ASCII:
44,193 001      8 01 01 01 03 04 05 06 07 ASCII:
44,195 001      8 F8 01 02 03 04 05 06 07 ASCII:
44,196 001      8 01 01 01 03 04 05 06 07 ASCII:
44,197 001      8 F9 01 02 03 04 05 06 07 ASCII:
44,199 001      8 01 01 01 03 04 05 06 07 ASCII:
44,200 001      8 FA 01 02 03 04 05 06 07 ASCII:
44,201 001      8 01 01 01 03 04 05 06 07 ASCII:
44,202 001      8 FB 01 02 03 04 05 06 07 ASCII:
44,204 001      8 01 01 01 03 04 05 06 07 ASCII:
44,205 001      8 FC 01 02 03 04 05 06 07 ASCII:
44,206 001      8 01 01 01 03 04 05 06 07 ASCII:
44,207 001      8 FD 01 02 03 04 05 06 07 ASCII:
44,209 001      8 01 01 01 03 04 05 06 07 ASCII:
44,210 001      8 FE 01 02 03 04 05 06 07 ASCII:
44,211 001      8 01 01 01 03 04 05 06 07 ASCII:
44,213 001      8 FF 01 02 03 04 05 06 07 ASCII:
44,214 001      8 01 01 01 03 04 05 06 07 ASCII:
44,215 001      8 00 01 02 03 04 05 06 07 ASCII:
44,216 001      8 01 01 01 03 04 05 06 07 ASCII:
44,218 001      8 01 01 02 03 04 05 06 07 ASCII:
44,219 001      8 01 01 01 03 04 05 06 07 ASCII:
44,220 001      8 02 01 02 03 04 05 06 07 ASCII:
44,222 001      8 01 01 01 03 04 05 06 07 ASCII:
44,223 001      8 03 01 02 03 04 05 06 07 ASCII:
44,224 001      8 01 01 01 03 04 05 06 07 ASCII:
44,225 001      8 04 01 02 03 04 05 06 07 ASCII:
44,227 001      8 01 01 01 03 04 05 06 07 ASCII:
44,228 001      8 05 01 02 03 04 05 06 07 ASCII:
44,229 001      8 01 01 01 03 04 05 06 07 ASCII:
44,231 001      8 06 01 02 03 04 05 06 07 ASCII:
44,232 001      8 01 01 01 03 04 05 06 07 ASCII:
44,233 001      8 07 01 02 03 04 05 06 07 ASCII:
44,234 001      8 01 01 01 03 04 05 06 07 ASCII:
44,236 001      8 08 01 02 03 04 05 06 07 ASCII:
44,237 001      8 01 01 01 03 04 05 06 07 ASCII:
TestOnOld.fcfx
(18.82 KiB) Downloaded 284 times
Barmaley_GMN
How can I check if TXB0CTRL.TXREQ MCP2551 is 0?
LeighM
Post by LeighM »
Your CheckTx0 looks OK to me.
Could you perhaps drop the return value (Free0) into the SetTxData (maybe after Free1) and see what is being returned?
Maybe do not mask the Status byte, just to see it's full value.
Barmaley_GMN
I have to change macro CheckTX1 to
FCR_RETVAL = FC_CAN_SPI_CAN_Status_2(160);
switch (FCL_BUFFER)
   case 0: FCR_RETVAL = FCR_RETVAL;
LeighM
Post by LeighM »
Sorry, ignore my last post :)
I've just noticed that you set the value of Free1 with the CAN status byte in CheckTx0()
The last log text that you posted, is that with the "while Free0" code disabled?
If so, what happens when you enable that code?
Barmaley_GMN
I've rebuilt scheme with 15f25K80 and will check
Barmaley_GMN
17,079 6C1      8 01 01 00 03 00 00 00 00 ASCII:
17,080 6C1      8 12 01 04 03 00 00 00 00 ASCII:
17,081 6C1      8 23 01 08 03 00 00 00 00 ASCII:#
17,083 6C1      8 34 01 08 03 00 00 00 00 ASCII:4
17,084 6C1      8 45 01 0C 03 00 00 00 00 ASCII:E
17,085 6C1      8 45 01 0C 03 00 00 00 00 ASCII:E
17,086 6C1      8 45 01 0C 03 00 00 00 00 ASCII:E
17,088 6C1      8 45 01 0C 03 00 00 00 00 ASCII:E
17,089 6C1      8 86 01 08 03 00 00 00 00 ASCII:
17,090 6C1      8 86 01 08 03 00 00 00 00 ASCII:
17,092 6C1      8 86 01 08 03 00 00 00 00 ASCII:
17,093 6C1      8 86 01 08 03 00 00 00 00 ASCII:
17,094 6C1      8 C7 01 08 03 00 00 00 00 ASCII:
17,095 6C1      8 C7 01 08 03 00 00 00 00 ASCII:
17,097 6C1      8 C7 01 08 03 00 00 00 00 ASCII:
17,098 6C1      8 C7 01 08 03 00 00 00 00 ASCII:
17,099 6C1      8 08 01 08 03 00 00 00 00 ASCII:
17,101 6C1      8 19 01 08 03 00 00 00 00 ASCII:
17,102 6C1      8 19 01 08 03 00 00 00 00 ASCII:
17,103 6C1      8 3A 01 0C 03 00 00 00 00 ASCII::
17,104 6C1      8 4B 01 08 03 00 00 00 00 ASCII:K
17,106 6C1      8 4B 01 08 03 00 00 00 00 ASCII:K
17,107 6C1      8 6C 01 0C 03 00 00 00 00 ASCII:l
17,108 6C1      8 6C 01 0C 03 00 00 00 00 ASCII:l
17,110 6C1      8 6C 01 0C 03 00 00 00 00 ASCII:l
17,111 6C1      8 6C 01 0C 03 00 00 00 00 ASCII:l
17,112 6C1      8 AD 01 08 03 00 00 00 00 ASCII:
17,113 6C1      8 AD 01 08 03 00 00 00 00 ASCII:
17,115 6C1      8 CE 01 0C 03 00 00 00 00 ASCII:
17,116 6C1      8 CE 01 0C 03 00 00 00 00 ASCII:
17,117 6C1      8 CE 01 0C 03 00 00 00 00 ASCII:
17,119 6C1      8 CE 01 0C 03 00 00 00 00 ASCII:
17,120 6C1      8 0F 01 08 03 00 00 00 00 ASCII:
17,121 6C1      8 0F 01 08 03 00 00 00 00 ASCII:
17,122 6C1      8 30 01 0C 03 00 00 00 00 ASCII:0
TestCheck.fcfx
(22.66 KiB) Downloaded 280 times
Barmaley_GMN
I'm confused.
How does it work?
Barmaley_GMN
12,454 6C1      8 01 01 00 03 00 00 00 00 ASCII:
12,455 6C1      8 01 01 00 03 00 00 00 00 ASCII:
12,457 6C1      8 01 01 00 03 00 00 00 00 ASCII:
12,458 6C1      8 01 01 00 03 00 00 00 00 ASCII:
12,460 6C1      8 01 01 00 03 00 00 00 00 ASCII:
12,461 6C1      8 01 01 00 03 00 00 00 00 ASCII:
12,462 6C1      8 01 01 00 03 00 00 00 00 ASCII:
12,464 6C1      8 01 01 00 03 00 00 00 00 ASCII:
12,465 6C1      8 01 01 00 03 00 00 00 00 ASCII:
12,466 6C1      8 01 01 00 03 00 00 00 00 ASCII:
12,468 6C1      8 01 01 00 03 00 00 00 00 ASCII:
12,469 6C1      8 01 01 00 03 00 00 00 00 ASCII:
12,470 6C1      8 01 01 00 03 00 00 00 00 ASCII:
12,472 6C1      8 01 01 00 03 00 00 00 00 ASCII:
12,473 6C1      8 01 01 00 03 00 00 00 00 ASCII:
12,475 6C1      8 01 01 00 03 00 00 00 00 ASCII:
12,476 6C1      8 01 01 00 03 00 00 00 00 ASCII:
12,477 6C1      8 01 01 00 03 00 00 00 00 ASCII:
12,479 6C1      8 01 01 00 03 00 00 00 00 ASCII:
12,480 6C1      8 01 01 00 03 00 00 00 00 ASCII:
12,481 6C1      8 01 01 00 03 00 00 00 00 ASCII:
12,483 6C1      8 01 01 00 03 00 00 00 00 ASCII:
12,484 6C1      8 01 01 00 03 00 00 00 00 ASCII:
12,485 6C1      8 01 01 00 03 00 00 00 00 ASCII:
12,487 6C1      8 01 01 00 03 00 00 00 00 ASCII:
12,488 6C1      8 01 01 00 03 00 00 00 00 ASCII:
12,490 6C1      8 01 01 00 03 00 00 00 00 ASCII:
12,491 6C1      8 01 01 00 03 00 00 00 00 ASCII:
12,492 6C1      8 01 01 00 03 00 00 00 00 ASCII:
TestCheck.fcfx
(22.68 KiB) Downloaded 243 times
