Decision component for simulation only
Is it possible to have a dragable decision component that the true branch is accessed during simulation only?
The false branch is for when running of hardware.
I have set up a few flowcharts that work like this but there are a fair few steps involved.
Would be nice to drag a single decision branch instead.
- Steve
- Has thanked: 114 times
- Been thanked: 422 times
Re: Decision component for simulation only
That's a good idea. I'm sure Ben and Leigh know a few tricks, but in the meantime, here's a possible workaround...
1) Create a variable and set it to zero ("IsSimulating = 0").
2) Use a simulation event (e.g. Time::GetMillisecs) to set it to a value
3) Use an "if (IsSimulating <> 0)" decision to determine if you are simulating or not
I've not tested this, but it should work because step 2 will be ignored in the microcontroller code and so "IsSimulating" will remain zero when running on a device but will be set to a non-zero value when simulating.
Steve.
Steve.
- LeighM
- Has thanked: 481 times
- Been thanked: 699 times
Thanks Steve, and for reminding me to comment
I've done this with a "Simulating" property (value 0 or 1)
Set the property value in a Ev event Simulation Start,
and clear the property value in a Ev event Simulation Stop.
I think this idea came from Ben, so he probably does similar.
Leigh
Leigh
Thanks Guys,
I have been following this post.
Just thought a more instant solution would be beneficial for all?
Yes a great idea Martin,
Here's a quick go at a simple component complete with source.
I'll add an icon and a simple GUI and add it to the v8 release.
Inside the decision icon just add this code.
No = MCU, Yes = Sim Runtime
IsSim1::Check()
Just looked into this.
Do you have to add to flowchart, ,, & if using component?
If so, do you believe its easier than this?
Ev_Initialise
Ev_Comp_Start
Ev_Start
Ev_Stop
.Return = Sim
You shouldn't have to add any of that.
It should be a case of add the component, Add the code to the decision icon. Job done
Thanks Ben,
Tested on hardware and working better than expected as did not need to add, So no need to memorise!
It works buy just using the the component: I will be adding Is Sim component to every flowchart that uses RX interrupt!
Woops Sorry, I did not see the words source, so thought Flowchart posted was an example.Benj wrote:You shouldn't have to add any of that.
IsSim1::Check()
