16LF18857
Jan Lichtenbelt
Has thanked: 128 times
Been thanked: 264 times
16LF18857
Post by Jan Lichtenbelt »
I like to use the 16LF18857 only with 32MHz internal oscillator and MCLR pin as input pin. In the test program I just set 2 ouput pins on, but it does not work. Wrong config word? Or something else?
Kind regards
Jan
Test_LEDs.fcfx
(7.12 KiB) Downloaded 279 times
CSM2711
Has thanked: 1 time
Been thanked: 9 times
Re: 16LF18857
Post by CSM2711 »
I think you should use a output component (LED) to visualize the Programm and configure the Port pins.
Re: 16LF18857
Configuration settings look ok to me. What voltage are you running the device at?
Looks like you need to be between 2.5V and 3.6V for the LF device to run at 32MHz.
Jan Lichtenbelt
Re: 16LF18857
I use 3.3 Volt as power for this microchip.
kind regards
Jab
Jan Lichtenbelt
Re: 16LF18857
Becasue the problem can also be a hardware problem, I made a new set up by means of a breadboard, see picture. But the same results, no green and/or red LED's are going on. I changed the flowcode that all A-ports should be going on and all C-ports. Nothing happens.
16LF18857 breadboard.jpg (129.24 KiB) Viewed 5380 times
Remark: Yellow LED is power on.
What to do now?
Kind regards
Jan
Re: 16LF18857
Hi Jan,
Are you having any progress with this?
Does the program go into the micro ok? If not then can you shorten your programming cable at all?
Jan Lichtenbelt
Re: 16LF18857
No progress. As far as I know the program has been stored correctly into the microchip. I only get the warning message that the "flash memory not verified".
"Attachment deleted by Jan"
What to do?
Kind regards
Jan
Last edited by Jan Lichtenbelt on Thu Apr 11, 2019 6:54 pm, edited 4 times in total.
Re: 16LF18857
Jan Lichtenbelt wrote:I only get the warning message that the "flash memory not verified".
Hi Jan,
In my experience that message is always displayed when mLoader was unable to program chip.
Have you got an alternative programmer you can try?
What happens if you load mLoader and select Autodetect ?
Jan Lichtenbelt
Re: 16LF18857
Hi Martin
Thanks for help. mLoader detects the chip 16LF18857.
What is the next step?
Kind regards
Jan
Jan Lichtenbelt
Re: 16LF18857
Decreasing the length of the ICSP cable from about 30 cm to 10 cm solved most of the problems.
Ben and Martin thanks for helping.
Kind regards
Jan
