Converting Big Endian to decimal
Steve001
Has thanked: 460 times
Been thanked: 523 times
Post by Steve001 »
Morning All,
Bit stuck again can somebody explain how to convert Float – Big Endian (ABCD) to Decimal please ?
I would like to understand how
43 6D 05 1F = 237.02
And
42 48 0F 5C = 50.015
i found something on the visual studio pages saying to read the bytes one at a time and reverse them.
I cannot get this to add up ?
mnf
Has thanked: 70 times
Been thanked: 440 times
Re: Converting Big Endian to decimal
Post by mnf »
This works (on an Arduino at least)
Uses an array of 4 bytes 'n and a float f and a string t (meaningful names!?)
The C code puts the hex given into a float in reverse order (so f[3] = h[0]) and converts from hex to a float using a union...
Just output converted value to UART as a test... (In this case 50.014999)
(An alternative approach would be to take the address of the float as a pointer to byte and add the data using that?) - and the second C block shows one way to do this (with the values hardcoded here!) which just pushes the value directly into a FC variable - I would suggest creating a function taking an array of 4 hex digits and returning a float!
Note: You could use a loop with *p++ = FCV_N[3-i] or as in first block p[3-i] = FCV_N) as a more readable alternative in the second C block.
mnf
Post by mnf »
More usefully as a macro....
float.fcfx
(9.88 KiB) Downloaded 614 times
Steve001
Post by Steve001 »
hi Martin
Thank you for that i will have a look later
Steve001
Post by Steve001 »
sorry i didn't understand it, could you explain how it works and what is happening please
I dont have an adrunio either to try and use.
mnf
Post by mnf »
The computer memory is an 'array' of 8 bit 'cells' with an address for each (so for an Arduino - the address could be 0..2047 for it 2048 byte RAM)
A 'variable' in a program is actually the address of one or more bytes in memory (so for a float (32 bit) it would point to 4 bytes somewhere in the memory)
So - a float f (32 bit) is stored in memory at 4 consecutive locations which the program can read and write to to manipulate the value of 'f'
'f' might be '12' (the address - not the actual value of the variable) and would reference the memory at addresses 12,13,14,15) - when a program uses a variable - the MCU loads from this memory address into a register - performs some calculation on it - then stores it back...)
The '&' operator gets the address of a variable - and then we 'poke' (to use a basic term) or store the values we want into the memory cells - and we can just treat this address as a pointer to an array (we've specified a point to a byte (MX_UINT8) - so we are just writing a byte at a time - then it's just a matter of storing the values we want in the right order)
Then when our program accesses the variable it retrieves the values we stored - and treats them as a (in this case) floating point value..
The C code won't simulate unfortunately.
More details if you wish?
Steve001
Post by Steve001 »
What I don't under stand is how do I get from :
my 4 bytes of data : 0x43 0x6D 0x05 0x1F
So looking at data stream - this should be 237.02
hex to decimal
43 = 67
6D = 109
05 = 5
1F = 31
so if I simply add those together as first thought = 212
another example I found was to convert the number to binary then apply 2's complement - this turned out to be a load of rubbish.
= 11010100
2's complement
= 00101100
converted to decimal = 44
mnf
Post by mnf »
So the 4 bytes represent a 32 bit (4x8) floating point number.... Adding them doesn't do what you want - they are just a representation of the underlying 32 bits of data...
See https://en.wikipedia.org/wiki/IEEE_754 if you want a summary of the full low down (and I suspect IEEE754 is a huge document - for the ultimate go to guide) as to how the binary represents the float.
Steve001
Post by Steve001 »
Hi Martin
thank you wow ... that's a pretty hefty document :shock:
http://www.thefullwiki.org/IEEE_754-2008
after a quick look I am going about it incorrectly,
mnf
Post by mnf »
I used https://www.scadacore.com/tools/program ... converter/ to check the required layout.
Tambala
Post by Tambala »
mnf wrote:I used https://www.scadacore.com/tools/program ... converter/ to check the required layout.
First time I see this website! Thank you very much for sharing this information, will try to use it soon for my work.
