RTC for Miac(Part One)
Enamul
Has thanked: 271 times
Been thanked: 814 times
Re: RTC for Miac(Part One)
Post by Enamul »
I made the program in Flowcode V4.5 It should work in Flowcode V5.4 but I am getting the same error..seems they are not compatible..Don't worry allow me some minutes..I am posting program using FCv5
Enamul
University of Nottingham
enamul4mm@gmail.com
acestu
Has thanked: 783 times
Been thanked: 223 times
Post by acestu »
Thanks Enamul
Acestu
Enamul
Post by Enamul »
Hi Stuart,
I have linked the FCV5 bug correction earlier and I forgot that now..Here is the bug correction link..
http://www.matrixmultimedia.com/mmforum ... 512#p38512
You will see FC5_PIC_CAN.c file to download in the link...Replace the old one in "Flowcode/v5/Components" directory..
Edit: so last posted program will compile after fixing the bug.
Enamul
enamul4mm@gmail.com
acestu
Post by acestu »
Hi Enamul,
Not having much luck, problems with the dev board now, the green power light will not come on now and the voltage regulator on the board is red hot ?
thanks
Acestu
Enamul
Post by Enamul »
ohh.. :(
Did you manage to compile the code?
Enamul
enamul4mm@gmail.com
acestu
Post by acestu »
Ok that was weird, its working now, yes I have just programmed the chip, getting late now though so I will carry on tomorow Enamul, and
as always thank you for your time and help
Acestu
Enamul
Post by Enamul »
Glad it worked finally..No problem we will start tomorrow..Good Night :)
Enamul
enamul4mm@gmail.com
acestu
Post by acestu »
Hi Enamul,
I am building the send receive master first, the switch on port b4 would this connect to +5v or ground
thanks
Acestu
Enamul
Post by Enamul »
Hi Stuart,
You have to connect RB4 to Vcc via 4.7K resistor..a switch from RB4 to GND. Pressing sw, RB4 = 0 and normally high.
Enamul
enamul4mm@gmail.com
acestu
Post by acestu »
Hi Enamul,
the switch, is it a momentary action or latching ?
thanks stuart
Enamul
Post by Enamul »
You can use momentary switch as whenever you press switch data will send to slave and master will be in another loop for data receiving..
Enamul
enamul4mm@gmail.com
acestu
Post by acestu »
Hi Enamul,
I have just finished the second node, I am going to join them both on the canbus now, do the end of line resistors have to be dead on 120 ohms because I dont have any at this value ?
thanks
Acestu
JohnCrow
Has thanked: 364 times
Been thanked: 716 times
Post by JohnCrow »
Hi Stuart
I dont think the value its too critical.
I'm using (measured with the DVM) 118.3 ohms on the termination for my miac expansion modules (the miac end is built in)
That is also the value I get if I measure across the CAN terminations on the E-block can board.
acestu
Post by acestu »
Thanks John,
The nearest I have is 100 ohms, but I have read articles that say people have used 60 ohm resisters, so I don't know, what is the worst that will happen, it won't work ?
thanks
Acestu
Enamul
Post by Enamul »
Hi Stuart,
According to datasheet of MCP2551, you should be fine if you use even 60 ohm. So I think you can simply connect 100 ohm for both terminals.
Enamul
enamul4mm@gmail.com
acestu
Post by acestu »
Hi Enemul, I have connected up the bus with the 100k resisters but nothing seems to work unfortunately, any ideas ?
thanks
Acestu
JohnCrow
Post by JohnCrow »
100 k or is that a typo? hopefully you mean 100 ohm :)
acestu
Post by acestu »
Sorry you are right John, its a typo
thanks
Acestu
Enamul
Post by Enamul »
Hi Stuart,
What is shown in slave and master display? Because the program is tested one and should work straight way.
Enamul
enamul4mm@gmail.com
acestu
Post by acestu »
Hi Enamul, the Master says "NO-TRANSMISSION" and the slave says "NOT-RECEIVED"
When the button on the Master is pressed the Master says "CAN-TRANSMISSION 84" and then changes to "NOT-RECEIVED"
The slave does not change
thanks
Acestu
P.S. I am using the temp sensor for the analogue input
Enamul
Post by Enamul »
When you press the button, you should see "CAN Transmission" in first line and 84 in second line. Are you getting that? You mean in slave you always see "Not-Received"?
Enamul
enamul4mm@gmail.com
acestu
Post by acestu »
Hi Enamul,
Yes that is what the master does, but the slave never changes it always says "NOT-RECEIVED"...
thanks
Acestu
Enamul
Post by Enamul »
I have modified the code for you that John used couple of days earlier. It is tested in FCV5..If it doesn't work in your case; I have to think in circuit connection and programmer issue.
ADC-Switch TX.fcf
(18.38 KiB) Downloaded 314 times
ADC-Switch RX.fcf
(34.59 KiB) Downloaded 283 times
Enamul
enamul4mm@gmail.com
acestu
Post by acestu »
OK, I have checked all my connections and found both mcp chips pins 5 to 8 back to front, I changed them and now it is sending info and returning info
thanks
Acestu
Enamul
Post by Enamul »
SO you mean now you can get data sending from master to slave and slave returning to master using the previous programs? If so, great well done! I am sending now one program for RTC with set options..
Enamul
enamul4mm@gmail.com
