SD e-block
proton
Flowcode V4 User
Has thanked: 1 time
Re: SD e-block
Post by proton »
I have not tried a full format, What happens even when using your .wav test file is that it will play approx. 2 seconds absolutly fine then it hangs up with a hissing sound followed shortly with a sound like a stuck CD and stays like that until i reset it and it starts again then hangs up again in exactly the same spot. No i do not get the "end of file" prompt on the LCD
wayne
Re: SD e-block
Hi Wayne,
Try a format of the card and let us know how you get on. I will try and have a quick go here if I get 5 mins to see if I can replicate the issue.
proton
Flowcode V4 User
Has thanked: 1 time
Re: SD e-block
Post by proton »
Hi Benj
Done a full format and still get the same result :(
Rgds
Wayne
proton
Flowcode V4 User
Has thanked: 1 time
Re: SD e-block
Post by proton »
Benj,
Any luck replicating this fualt on your set up
Wayne
Re: SD e-block
Hi Wayne,
Right I have rigged it up using your program and it runs fine for me. I am using a 2GB SD card, compiling using v4.5 and streaming the files from the original article.
Here are my files.
Sound Wav Player FAT16 V0.4.c
(83.67 KiB) Downloaded 406 times
Sound Wav Player FAT16 V0.4.hex
(27.78 KiB) Downloaded 357 times
Sound Wav Player FAT16 V0.4.fcf
(16.03 KiB) Downloaded 386 times
You could use a comparison tool like ExamDiff to compare my C file with yours to see if there are any major differences.
