Ultrasonic Transducer Module Car Alarm
- acestu
- Has thanked: 783 times
- Been thanked: 223 times
Re: Ultrasonic Transducer Module Car Alarm
Hi Martin,
That's great news, the more the merrier, I think combined with the PIR module this would make a great little alarm system...
Acestu
Acestu
- acestu
Hi guys,
I have just bought one of these is any of you are interested, great price I thought.....
http://www.ebay.co.uk/itm/120895737622? ... 1439.l2648
and I think it will go nicely with the microwave unit.
Acestu
Acestu
That looks great!
You have go a keen eye for a bargain!
That's a good idea for a new eblock, PIR Eblock as well as utrasonic transducer eblock:P
- Enamul
- Has thanked: 271 times
- Been thanked: 814 times
Yes, Martin is right. These could be gathered in a handy Eblock. Good findings Stuart
We are currently working on sensor prototypes including PIR and Ultrasonic sensors which will be available to plug into our up and coming sensors board and robotics platforms. Probably looking at something like a summer release for these.That's a good idea for a new eblock, PIR Eblock as well as utrasonic transducer eblock:P
That sounds great Ben.
Will The new eblocks have there own component created in Flowcode so an update is required, or do we have use delays, inputs etc for the new eblocks to work?
- acestu
Hi Guys,
I have started putting a program together for the car alarm, however I have just come to test the first bit of it and the output does not trigger, I think that I might have the wording wrong in the Decision in the Alarm On Macro, could somebody help me please ?
Thanks In Advance
Acestu
Thanks In Advance
Acestu
- acestu
Hi Guys,
I sussed this bit out I substituted + for AND.....
cheers
Acestu
cheers
Acestu
- acestu
Hi Fellas,
Now that I have this alarm switching on, how do I implement the switching Off part, do I have to set up an Interupt ?
Thanks In Advance
Acestu
Thanks In Advance
Acestu
Hi Stuart, the alarm will only sound if both PIR AND Utrasonic alarms been detected.
If you want either then you can use | for OR.
| is the key which is shift backward slash.
As for the switching off.
Yes I would use a timer interrupt, so alarm not going of indefinitely which I believe is braking the law?
But could also annoy the neighbours, and could also flatten your battery.
- acestu
Hi Martin,
Yes that is what I was trying to do ie only go off when the pir and the microwave trigger, and I put 2 delays in so that it will go off for a maximum of 20 mins which is law then wait 5 mins before it rearms, I think I posted the wrong file before so I will post it again...
Acestu
Acestu
- acestu
Hi Martin,
I just watched this youtube video about flowcode interupts: http://www.youtube.com/watch?v=oiEi_ZBc618
However when I followed the instructions and set to interrupt on port the properties box was grayed out, do you know why this is please ?
thanks
Acestu
thanks
Acestu
Hi Stuart,
IOC mask register does not exist on the 16F877A, so does not give options for the PORT interrupt.
The device you used that gave port B interrupt selection options would have IOC mask register.
You have to use software to decide if the interrupt was from a required pin by saving the port value from the last interrupt and using bit masking.
Just bear in mind only pins RB4-RB7 can generate the PORT interrupt on this device so RB0 to RB3 can't be used for this purpose.
Going to work now, but there are posts that use masking techniques for port interrupt detection.
If your still stuck then let us know I I will find something for you.
- acestu
Hi Martin,
Do you think I am going down the right road here, ie should I be looking for a different device with this IOC masking ?
I looked for one before but you cannot search using this as criteria.
thanks
Acestu
thanks
Acestu
No you don't need to look for a device with the IOC register for your hardware to work the way you want it too.
you just need to add a little bit of code within the interrupt as stated earlier.
For instance have a look at this:
http://www.matrixmultimedia.com/mmforum ... 44&#p39310
I have illustrated how port interrupt detection can be achieved without IOC registor
- acestu
Hi Martin,
Just before I do that, can I just ask you something, I have been looking at the example on youtube and I picked the same chip used to do a little experiment,
So am I right in thinking that if you have the device with IOC masking then you could set up an interrupt on port then in properties choose the port that you are going to use and set it to rising edge (which I take it means that it will trigger when you apply a voltage to the pin) then connect your switch to that port and when you press it the Macro that you created will be called, if this is so I wonder why my little program does not work ?
thanks
Acestu
EDIT:
Sorry I have new file working now
thanks
Acestu
EDIT:
You have nearly got it.
Here what will happen:
Your program will be running normally.
port B Interrupt is detected.
You program temporarily pauses, all icons within interrupt is executed, program carries on from where it has paused from.
With your flowchart, you won't notice anything happerning because there are no instruction icons withing your interrupt, so what is happening:
You program temporarily pauses, nothing within portb interrupt so nothing different happens.
Program carries on from where it has paused from (which happened so quick, no difference can bee seen).
Try the attached file, It should simulate ok as well.
- Interupt_test2.fcf
- (11 KiB) Downloaded 241 times
Yes you have spotted what you have done wrong.acestu wrote: EDIT:
Good job
- acestu
Hi Martin,
I am not sure what the calculation LED_Enabled = !LED_Enabled is doing
thanks
Acestu
thanks
Acestu
Its just a bit wise toggle.
If LED_Enabled= 1
then after:
LED_Enabled= 0
Likewise if:
LED_Enabled= 0
Then after:
LED_Enabled= 1
Etc.
So each time interrupt is accessed:
If LED's flashing they will stop flashing.
If LED's had stop flashing then they will flash again.
If LED_Enabled= 1
then after:
LED_Enabled = !LED_Enabled is doingLikewise if:
LED_Enabled= 0
Then after:
LED_Enabled = !LED_Enabled is doingEtc.
- acestu
Hi Martin,
I thought the program was just paused so when it starts again all should be well, so why the need for the bit toggle (I have it in my head that the interupt is going to terminate the program so why is the toggle important), or are you giving me an example if it were important ?
This is sort of hard to explain
Eventually what I want to do is use part of another project which will allow me to turn the car alarm on and off with the 433 mhz tranceiver, so I have got to figure out how to stop the main program loop and go back the unset state, I am thinking I have got to use the interupt to terminate the current process and not just pause it, does this sound logical ?
thanks
Acestu
thanks
Acestu
It was not essential to show toggle. I gave that toggle example just so you can see that your program is not paused as you think it might be?
Each time you activate the interrupt, after interrupt has finished,as stated earlier your program carries on from where is has pause from to service the interrupt.
Since your program is running all the time, I just wanted to show you a method of pause program when interrupt activated once, then carry on when interrupt was activated again.
In reality what would would do is use interrupt to activate alarm e.g activate=1
Then you would create a timer interrupt so when 20 mins has passed then activate=0 will be executed.
Perhaps this will help?
http://www.matrixmultimedia.com/mmforum ... =36&t=6390
- acestu
Hi Martin,
I have looked at a few different articles on interrupts now, I found this one which is simple but I just can't see how it is working, could you have a look for me please and read the comments that I have put in it...
Thanks In Advance
Acestu
Thanks In Advance
Acestu
The program you posted just works with B0 interrupt.
Each time you press switch connected to B0, interrupt macro is serviced and 1 is added to your count variable.
Since in the main routine portA is using count then in effect every time interrupt is activated the LED's will count in binary
i.e
0
1
10
11
100
etc.
With only 4 LED's and count going from 0 to 255, you will not see the full effect.
If you want all four LEDs to light when interrupt is pressed then within interrupt change:
to
Its also good practice to double click on your port component within flowchart and select use masking. Select 0 to 3 for all your four LED's.
That way all port thats not used (B4 to B7) will not be affected.
If you use COUNT = 15 then when switch is pressed all LEDs will light up, and stay lit until power is removed.
That's what it looks like you want to do.
If not then let me know what you are trying to do and I can assist further.
Not simulation is not working correctly. LED's should only be changed when switch is pressed in, and not again when released since interrupt on rising edge is used.
I
i.e
0
1
10
11
100
etc.
COUNT = COUNT + 1Code: Select all
COUNT = 15That way all port thats not used (B4 to B7) will not be affected.
I
- acestu
Hi Martin,
I am just trying to understand how interupts work by following what the program is doing, the way it first looked to me is that when I press the button the macro is called sending power to the whole of port A, so I am thinking all LEDS on port A should light up but they are not.
I think this is similar to the old school yard joke ie what is 2 add 2 and you say 4 and they say No it's 22, as in when it adds 1 to count it is not just 1 on its own , it is 1 plus whatever is already there , and I think what you are saying is that these numbers are sent to port a and it is showing in light the equivelant binary set.
There now my brain is fried
thanks
Acestu
EDIT: Ha Ha 15 Decimal to Binary =1111, Am I correct in thinking that the word "COUNT" is a set command and not just a variable name of your choice ?
thanks
Acestu
