DS3231 - RTC Time Keeper
A forum where Flowcode v6 user created components can be shared, discussed and reviewed.
hyperion007
Has thanked: 49 times
Been thanked: 101 times
Re: DS3231 - RTC Time Keeper
Post by hyperion007 »
With 1.6 the dashboard "icon" showed the original I2C icon with the DS3231 name, but had the LCD icon "stuck" under the I2C icon :)
I'm going to use the alarm function to wake the PIC up from sleep mode at precise intervals, when the alarm function is working that is ;)
John, if you want I can make the PCB available for ordering from OSH Park and post the very simple schematic and short BOM.
Crenwick
Has thanked: 7 times
Been thanked: 21 times
Post by Crenwick »
Hi Jordy,
I'm using your component in my project and I'm facing a problem, when I power off the board the clock stay at the same time. It's like bit EOSC is set.
I supposed you cleared this bit with initializing macro ? Right ?
Bernard
Flowcode 6 / EB006-V9
Jordy101091
Has thanked: 25 times
Been thanked: 188 times
Post by Jordy101091 »
I will look into this, I apologise to all of you for not being so active lately.
I was looking for a new and first car for my self and that took a lot of my free time.
I hope you all can understand this :)
But I promise that I will become more active in the future.
Regards Jordy
Crenwick
Post by Crenwick »
No problem Jordy :wink:
Take your time !
Bernard
Crenwick
Post by Crenwick »
Hi Jordy,
I find the problem :wink:
Each time you configure the SQW rate you set also bit 7 (adding 0x80) who is disabling oscillator when on Vbat.
Actual Macro,
case 2:
//Comment:
//Enable Square Wave Output
//Frequency = 1Hz
FCD_005f1_I2C_Master1__TransmitByte(0x80);
break;
case 3:
//Comment:
//Frequency = 1.024kHz
FCD_005f1_I2C_Master1__TransmitByte(0x88);
break;
case 4:
//Comment:
//Frequency = 4.096kHz
FCD_005f1_I2C_Master1__TransmitByte(0x90);
break;
case 5:
//Comment:
//Frequency = 8.192kHz
FCD_005f1_I2C_Master1__TransmitByte(0x98);
break;
// default:
Can you mod the component :wink: ?
Bernard
hyperion007
Crenwick, could you please try the alarm functions as well? I cannot seem to get them working. I have tried both alarms, and many different settings but still nothing.
Crenwick
Post by Crenwick »
hyperion007 wrote:Crenwick, could you please try the alarm functions as well? I cannot seem to get them working. I have tried both alarms, and many different settings but still nothing.
Ok, I will test it :wink:
Bernard
Crenwick
Post by Crenwick »
Sorry for late reply, I tested and have no trigger from INT/SQW.
Just received my buspirate this week and will test the I2C analysys tool :wink:
Bernard
hyperion007
Thanks, that confirms my findings as well :(
hyperion007
Hi Jordy,
Any updates to the component? Kinda need the alarm functions etc :)
hyperion007
I have fixed the EOSC problem but cannot for the life of me figure out why the alarm rates aren't working.
hyperion007
If anyone want's to try it as is I have uploaded my revised version of the component.
Things to note are that I think only Alarm 2 once per minute rate works. Alarm 1 will probably not work at all.
But I do believe I have fixed the problem with the OSC shutting down when in Vbat state.
I just really needed to get the INT every minute to work and couldn't wait any longer.
DS3231.fcpx
Component version 2.1
(9.85 KiB) Downloaded 1675 times
hyperion007
If anyone that has a DS3231 could connect it up and also connect a display, then run a simple program (first you need to write time and date if that hasn't been done yet) that in the main loop reads the time and return it as a string, then display it on the display.
Keep this running for several days and just check it from time to time to see that it is not drifting in any way, time wise.
Mine has been running for a couple of days now and was doing just fine when I went to bed last night at 00:30 (so this morning really) but when I checked it at 07:31 this morning, it was showing something like 06:45
We did have some severe thunder and lightning last night but it shouldn't affect this... It would be nice to see if anyone else are having some "long term" issues.
I did in fact have it return a time saying such things as 29 hours and also 25 hours. This was a month ago I think, after having the DS3231 unplugged for a month maybe. It might have had something to do with the component setting the EOSC bit incorrectly before, I don't know. But it's good to have more people testing it.
hyperion007
I have now made some more tests with a second chip from this batch and it is also acting up, so if you see this Jordy, please check your's if you can but if not, just replace the chip with a DS3231SN directly Maxim Integrated or Mouser/Digikey etc.
"Good deals" from Ebay proving not to be that great : :evil:
hyperion007
I got the new IC's from Maxim Integrated on Monday and so far it is working just fine, not like the other IC's.
So I'll leave it running for a couple of days more but I think it's proof enough that the ebay IC's I got was faulty.
Jordy101091
Hi all,
First I want to apologize to you all, for not being a very active member lately.
But im trying to changes this, and want to start with fixing the problems you all have with this component.
The main issue as from what I understand, is that the alarm functions did not operated properly.
I have made some little changes in the code as well as the component properties window. Now you are able to disable timer 1 and 2, which seem to cause some
issues with initialization routine, If both alarms are disabled the program automatically disables the Alarm Interrupt Enable settings, so that there is a minimal change of conflict situations.
Also I have changed the clear alarm routine, so that takes fewer lines of code and therefore makes it more clearer, and a bit faster as well.
To use the alarms correctly you need to first set the function of the alarm (Alarm "nr"" Rate) in the properties window. If this is done you need to set the alarm information with the macro "SetAlarm1/2".
You need to periodically check the status flag of alarm to know if it has triggered, or you could use an interrupt for that as well. Ones an alarm event is happend you need to clear the alarm with the "ClearAlarms" Macro before another alarm event can happen.
I hope This clarifies a bit.
You can download version 1.66 from the mean post.
Regards Jordy
hyperion007
Thanks Jordy.
I can report that the problems I had with the RTC being reprogrammed seems to have been caused by me putting a delay in the INT routine for the alarm and also putting the clear alarm macro in the same INT routine. I do not know how this could cause the RTC time registers to get corrupted but they did.
Jordy101091
Oke,
Another thing I have noticed here on this topic is that the RTC won't tick when VDD is removed from the chip.
mmm... where did I see that message.
O wait here it is:
Hi Jordy,
Im a bit confused because when I power down the RTC by removing the VDD wire and re-connect that same wire 30 seconds later, the time on the RTC is correctly incremented 30 seconds.
Maybe Crenwick had bad battery perhaps.
Regards Jordy
hyperion007
There was a problem with the EOSC bit being cleared when clearing the alarms/checking the status. I think I corrected it in my not so pretty version :)
There wouldn't be any problem if you didn't clear any alarms and such, then it would still run on Vbat.
Jordy101091
Well that problem is now resolved,
Because I now use the XOR function the clear the alarm flags so the EOSC bit stays unchanged.
So this problem belongs to the past.
Regards Jordy
Jordy101091
Just for kicks,
I have added a option to choose between 24 Hr and 12 Hr (AM/PM) notation.
I thought this would be helpful since its also available in the DS1307 Component.
So Component is updated to version 1.67, download can be done from the main post.
Regards Jordy
hyperion007
Good, now while you're at it, could you make a macro for changing the alarm rate? It can be set to once per second, once per minute, once per hour, once per day etc. using the mask bits. It would be very good to be able to change rate from within the program.
Thanks.
Jordy101091
hyperion007 wrote:Good, now while you're at it, could you make a macro for changing the alarm rate? It can be set to once per second, once per minute, once per hour, once per day etc. using the mask bits. It would be very good to be able to change rate from within the program.
Thanks.
Consider it handled,
But would you prefer to have a separate macro for changing the alarm rate or does it need to added with the SerAlarm macro. Also do I need to remove that option from the properties window or leave that as it is.
Regards jordy
hyperion007
I think it would be less confusing if it was a separate macro from the set alarm macro.
Because when an alarm has been set once, changing the masking bits would change the rate without the need to change the alarm time (setAlarm)
I think you can leave it in the properties window, it's fine. But maybe add the different rates here as well because now it's only every second and every minute then other specific alarms like when minutes match etc. Missing are the once per hour, once per day etc.
Thanks.
Jordy101091
I have updated the component to version 1.68.
In this version it is now possible to change the alarm match condition on the fly.
The uC doesn't need reprogramming to change alarm match conditions.
Download can be done from the start post.
Regards Jordy
