In the background I can watch the events.
I also have a t6963c Controlling from the display.
Screen size 5,1inch
Resolution of 128 * 240 pixels.
Densitron 6229E
http://www.datasheetarchive.com/dl/Data ... 025582.pdf
T6963C Display Driver Support
Forum rules
- STibor
- Has thanked: 116 times
- Been thanked: 113 times
Re: T6963C Display Driver Support
Basic example program.
- t6963c.zip
- (6.31 KiB) Downloaded 555 times
Tony Brown
- Has thanked: 36 times
- Been thanked: 5 times
Did you every get one of those display? If not I got one I can send you.
Tony
Tony
bercioiu
- Has thanked: 90 times
- Been thanked: 34 times
There is any progress in component GLCD with T6963C controller? I have the same "image" on GLCD.
Thank you!
Puiu,
Thank you!
Puiu,
- (463.32 KiB) Downloaded 920 times
Hello, I have the same problem too! Anybody have a solution? I test with arduino mega 2560 and with 328p NANO, and the problem is the same. If i put a line running corner at corner i watch, but the another lines dont clean. This screen dont have pin FS
This is the screen that i use: (160x128)
http://www.artronic.com.pl/o_produkcie.php?id=1279?
And this is the problem:
Thanks!
Thanks!
- (3.33 MiB) Downloaded 725 times
