Using FFT_test.fcfx
Re: Using FFT_test.fcfx
Thanks for letting us know about the problem your facing. I will investigate and see if I can work out what's going wrong.
kersing
Has thanked: 553 times
Been thanked: 1081 times
Post by kersing »
Hi Larry,
What kind of wave form is you input?
Best regards,
Jac
― C.S. Lewis
SHORTCIRCUIT
Has thanked: 40 times
Been thanked: 19 times
Post by SHORTCIRCUIT »
Hi Jac
Wave form is sine wave from a function generator. I tried 0 center and also 0 at the bottom on the sine wave with the same results in both cases. I also checked the input sine wave on a scope.
500 hz.jpg (26.37 KiB) Viewed 20289 times
Larry
SHORTCIRCUIT
I just noticed in the console that the Input buffer contains 32 pieces of data which is correct for the buffer size allocated, however after the FFT is processed the console shows 192 pieces of data for FFT_Real buffer and the same for FFT_imag buffer which also has 32 spaces allocated for each. This does not seem right to me. Perhaps, this points to the problem.
Larry
I seem to be getting similar results so will continue this afternoon and see if I can find the source of the problem.
The console outputs any value written to the buffer, the FFT performs several passes as it re-orders the data and all of the passes will be shown on the console. Hence the extra values you are seeing.
SHORTCIRCUIT
Thank you. A solution would be awesome.
Larry
A solution would indeed be awesome. So far it is eluding me but I believe some progress has been made.
(1.24 MiB) Downloaded 6900 times
Red = Signal In
Green = FFT Output Real
Blue = FFT Output Imaginary
Black = FFT Output Frequency Banks
DSPFFT.fcpx
(21.17 KiB) Downloaded 476 times
I've spent most of the morning working on this issue and have made progress but don't seem to really be getting anywhere fast. So I will do some of my scheduled work and then jump back on this when I get some more free time.
Sorry the news couldn't be better. Is this for a commercial project and do you have a deadline you are working to?
SHORTCIRCUIT
Yes commercial project.
I don't have a hard deadline but I am being pushed.
Larry
Ok understood. I'm fairly certain the code is right but there is an overflow issue or something similar going on. I will do some more reading and check my maths is making sense.
SHORTCIRCUIT
Thanks for the update. Eagerly awaiting a solution.
By the way, this is not a chip specific problem I hope, as I intend to migrate to 30F3012 (18 pin) as the final chip. I'm presently using the 4013 because of the extra peripherals to aid in the diagnostics as the program evolves.
Larry
Hello Larry,
No it's not chip specific, it's a problem with the maths.
Progress...
I have started again in a blank Flowcode project and have now managed to get somewhere.
Here is a file which shows how I got it working. Depending on your application this file may be enough to allow you to continue.
FFT_Rehash.fcfx
(25.63 KiB) Downloaded 399 times
I've not tried it on hardware yet but I'm hopeful.
Tomorrow I will take this code and place it back into the DSP component so hopefully this can function correctly too.
kersing
Post by kersing »
Gents,
Please keep in mind you might get artefacts if the sample does not start and end at a zero crossing of the input sine. Using a window function (Hanning, Hamming or any of the others) will reduce that effect, but not eliminate it. Also I found I had to reduce the amplitude of samples by half to prevent overflow while working with FFT. (I'm using dsPIC FFT functions as used in my article wrapped in a FC6 component)
Best regards,
Jac
― C.S. Lewis
I've managed to make some progress and route out a few bugs.
DSPFFT.fcpx
FFT Component - Fixed FFT Maths Routines
(15.62 KiB) Downloaded 301 times
DSPFreqGen.fcpx
Freq Gen - Fixed a problem with 16-bit data being stored in 8-bit locations
(32.89 KiB) Downloaded 400 times
lut.fcpx
LUT - Fixed a problem with negative numbers
(5.95 KiB) Downloaded 327 times
Here is my test program.
DSPFFT.fcfx
FFT Test Program 30F4013
(28.79 KiB) Downloaded 349 times
This is working great in simulation and on hardware. I've just tried with some real world data and this also seems ok though still not perfect. This could be down to what Jac also noticed. I will see if we can add a simple windowing filter on the data before we run the FFT calculations to see if this improves things.
Let me know how your getting on.
SHORTCIRCUIT
I played with it and still don't get useful output data from the bins. My program will be making decisions based on certain bin content and will not be reconstructing any of the output as it has no use after the bin data evaluation.
I noticed that your clock is set at 96Mhz and timer-1 set at 16khz and FFT sampling at 8khz. Should those numbers be significant to me, or is that just where you left them for your testing purposes?
Larry
Hi Larry,
I have now added a filter property to automatically do a window filter on the data and this is now giving me a very nice frequency spike.
DSPFFT.fcpx
(14.02 KiB) Downloaded 405 times
SHORTCIRCUIT
Will do more tests later today
Larry
SHORTCIRCUIT
Seems to be very much improved. I am getting some usable results.Is it now complete, or is there more tweaking to do?
I will be doing more experiments today.
Larry
SHORTCIRCUIT
It seems that discrimination between frequencies is poor. For instance, I set up to read the 500hz bin and get a a level of 120 from that bin with 500hz signal applied, then I take the freq on the function generator up to higher frequencies in 100hz steps up to 1khz and still get 120 and higher from the 500hz bin. I would expect that as I move away from the frequency designated for that bin, that the number in the bin would diminish substantially.
I am using a sample rate of 2000 with sample count of 32 so I get 16 bins 63hz per bin.
Larry
Hi Larry,
Can you attach your program or a simplified version which exhibits the problem and I will investigate for you.
SHORTCIRCUIT
Here is the latest version of my program, as it seems to change minute by minute. Presently, I am getting values in the #9 bin at frequencies 250hz, 650hz and 750hz. These are the frequencies I input from a function generator with clean sine wave as shown in the photo of my scope in a previous post several above this one.
I am sampling at a rate of 2000 for 32 samples, so that I get 16 bins of final FFT data. Input is 1volt p-p with 0 center.
Larry
FFT_3012_LED.fcfx
(21.28 KiB) Downloaded 358 times
Update: As I was writing this post, I tested with function generator set to 0 at the bottom of the sine wave and was able to get better discrimination.
Hi Larry,
Aha yes that might explain things. The ADC input has to be positive, negative voltages will just be read by the micro as 0's. You then subtract an offset from the value in software to get the signal centred around the 0 position. The closer you can get this offset the better frequency discrimination you should achieve.
For example input voltage = 5V peak to peak sinewave, centred around 2.5V
The ADC reads the value as 10-bit Int to give the value 0-1023.
Subtracting 512 from the ADC input will give you -512-511 with the mid point at 0.
If the input voltage is instead 2V peak to peak sinewave, centred around 1V
The ADC reads the value as 10-bit Int to give the value 0-409.
Subtracting 205 from the ADC input will give you -205-204 with the mid point at 0.
You could do automatic level detection in your program by using the DSP level component and collecting the max and min values from the input buffer before subtracting the offset and running the FFT.
Offset = (Max - Min) / 2
Signal = Signal - (Offset + Min)
Here is an example with my attempt at auto levelling.
DSPFFT3.fcfx
(26.45 KiB) Downloaded 347 times
It doesn't work as well as I was hoping. Could be that auto levelling is a bad idea and instead you need to get the levels from the average of several buffers to get a true idea of the actual min and max.
Luckily the DSP Level component has a property to allow you to do just that :D
Upping the decay to 10 does seem to be better but still not as good as simply subtracting the fixed offset.
A decay of 25 seems better again.
SHORTCIRCUIT
Thank you for the response.
I believe the adc on the 30F3012 is 12bit, so full scale 4095. If this is correct I can adjust what you said above to this value. Please comment.
Larry
Hi Larry,
Yep 12-bit ADC = 0-4095
Subtracting 2048 from the ADC input will give you -2048-2047 with the mid point at 0.
The ADC reads the value as 12-bit Int to give the value 0-1638.
Subtracting 819 from the ADC input will give you -819-819 with the mid point at 0.
