DsPIC stops running if GLCD is included in the program
Zane
Flowcode v5 User
Has thanked: 93 times
Been thanked: 76 times
Re: DsPIC stops running if GLCD is included in the program
Post by Zane »
Hi Ben,
No worries, i will look into that for you and post what i find. Enjoy your time off.
Zane
Zane
Flowcode v5 User
Post by Zane »
Hi Ben,
I have attached some code for a component to drive the 4D display running the R44 firmware revision (EB076_V2). This allows the display to initialise and also allows images to be displayed off the SD card. I hope this helps with sorting out the Flowcode component.
The only problem that this component has is that when the high speed baud rate is selected, the fastest I can drive the display is at 38400 bits/s. Any faster and the PIC starts sending data with errors, hence the high speed baud rate being set to 38400bits/s.
If anyone is interested in using this code and they are unfamiliar with creating components, open the attached flowchart and select “file” and then “ export component”. Save this component file in the components folder of FlowcodeV6 to make it available for use in a program.
Component4D_R44Picaso.fcfx
(48.88 KiB) Downloaded 491 times
