Page 2 of 2
Re: 32MS250 Oscillator failure
Posted: Mon Dec 05, 2016 3:34 pm
by QMESAR
Thank you so much Ben I will be very happy if we could find the problem :D
Posted: Mon Dec 05, 2016 5:29 pm
Hi Peter,
Right here is a slightly modified definition file that will allow you to enter 80000000 as the clock speed.
32MX250F128B.fcdx
(39.08 KiB) Downloaded 236 times
Hopefully this is all that is needed and it is me reading the datasheets wrong, it says 40MHz is the max speed but there is a divide by 2 so it kind of makes sense that 80 is the right speed. We shall see...
Let me know if this helps to bring any more sense to the situation.
Posted: Mon Dec 05, 2016 5:52 pm
by QMESAR
:D
Ben still running at half the speed
Thanks for the help
update
The following I noticed the interrupt fires as before more or less at half speed then I removed the Interrupt and used again a delay block with the new 80Mhz setting that seems to be 1/10 of what it should be 10mSec = 100Hz I measure 12Hz
I give up :oops:
Posted: Wed Dec 07, 2016 8:26 pm
by QMESAR
Update :
I was confusing myself yesterday I think I did not restart FC after I installed your new fcdx file :oops: sorry about that however after going threw the whole situation again today
I can say that the timing seems to be correct now as my interrupt fires exactly on the set times with the OSC setting at 80000000 Hz ,However as mentioned once or twice before the delay blocks seems to be out why that is I have no idea
Just thought I will inform you about the new fcdx file is there no one here that is working with this device just to verify my findings especially the issue with the delays it seems I am working against myself with this at the moment if I am incorrect it would be nice to know that
Thanks so much for all your help
