I'm not seeing the compilation error here. Sounds like you maybe have an old CAL C file. Can you try clicking Help -> Check for updates to make sure your using the latest release.
If your still getting the error then it may also be worth applying the latest post release fixes from here.
viewtopic.php?f=63&t=18760
Not sure why the send string would take so long, I assume when it does send out data that it's at the correct baud rate. In your config you have the watchdog timer enabled, this could potentially be causing an issue.
To get 64MHz using the intosc you may need to add this using a C icon at the start of your project. At least that's what the INTOSC Helper component is saying. If your timer is running at the right rate then it maybe already set to this value. Looking at the datasheet this value comes from the configuration so may not actually be needed.
OSCFRQ = 0x08;
