ADC Component change ref voltage
Re: ADC Component change ref voltage
Hi Steve,
If you compare side by side the register you did (Branch 1) with and existing register I did (Branch 2) with the C code there is a difference in format: Martin
Steve001
- Has thanked: 460 times
- Been thanked: 523 times
right a better result tonight
register ADPCH
Scope volts on AN32 - E0 225.1 mv
pass 1 251
pass 2 128
pass 3 255
pass 4 235
pass 5 162
pass 6 214
no binary values displayed
register ADPCH
pass 1 251
pass 2 128
pass 3 255
pass 4 235
pass 5 162
pass 6 214
Hi steve I'm away for the weekend. So only got mobile.
Since ADPCH enables the required ADC channel then from memory with value left as zero then only An0 is active.
I did suspect that hence the reason for connecting the pot to An0 pin.
I thought if a voltage is applied to An0 pin the correct ADC value word be shown.
Maybe this is one for Matrix staff to sort out, but I will see if I can find out why correct values are not being transferred to ADPCH on sunday evening when back home if not too late.
Hi Steve.
I have had a look at PIC_CAL_ADC.c and it looks like the ADC channels only go up to 24 whereas your device has got 34
ADC channels.
As you was selecting ADC channel 32 then PIC_CAL_ADC.c would not be picking it up.
Can you select a ADC channel higher than 0 but lower than 24.
Connect pot to it, then recompile.
If you can't connected a pot to an ADC channel lower than 24, then I can add ADC channel 32 to PIC_CAL_ADC.c and send it to you.
Don't know if any other issues until the above is tried.
ADC channels.
- LeighM
- Has thanked: 481 times
- Been thanked: 699 times
Thanks for the spot, fix here ...
http://www.flowcode.co.uk/mmforums/viewt ... 64&t=19112
Steve001
Evening All,
Struggling again
using the "read ADC voltage as string example " in the tutorials - this works ok correct readings but my input voltage is 220mv
Adding a c code icon with "FVRCON = 0x81;"
and changing the VREFOP to FVR and Vrefvol to 102
didn't give the expected results the voltage displayed is 1.018890V and doesn't seam to change
reading the data sheet bit ambiguous and confusing
When you start using FVR module is this only available on ADC1 ? as the data sheet seams to indicate this see page 266 onwards (cannot find the exact spot where I read this now sorry)
data sheet here
http://www.farnell.com/datasheets/22452 ... 1501615565
haven't tried martins program to read the registers yet will have another go tomorrow with that
should RA3 (pin 5) be outputting 1.024 Volts ? as it was all over place on my scope
Struggling again
data sheet here
Hi Steve,
So any FVRCON or other registers set, the ADC component will override them.
I have posted about that here.
It was not for your target device, but principle will still be the same.
No it won't as FVRCON is set within ADC component.Steve001 wrote:Adding a c code icon with "FVRCON = 0x81;"
Steve001
Hi Martin
struggling again and getting confused
after looking at the component as you suggested (didn't mean much i must admit)
dose this mean that the component supports a setting of the FVR ?
i have tried several things now , and made a test circuit on a EB17 pcb - Attached
but cannot get it to work when trying to set fvr to 1.0124 volts
the correct voltage is displayed when set at 5 vcc can read 1.024 & 2.5 volts
do you have any ideas ? as i am at a total loss now
steve
:edit - drawing for reference only
switch (Vref)
case 1: // Vref selected
ADCON1 |= 2;
break;
case 2: // FVR selected
ADCON1 |= 3;
FVRCON |= 0x81; // ADC FVR output is enabled, 1x (1.024V)
break;
default: // VDD selected
break;i have tried several things now , and made a test circuit on a EB17 pcb - Attached
steve
Hi Steve,
Select properties of POT and make sure you have FVR selected within Vref option.
I have had a go at changing C code within PIC_CAL_ADC.c
Looking at the Code what Ben suggested should have worked and what I said should not apply.
If properties was not on FVR, after changing just recompile.
Just in case does not work?
Can you make a back up copy of PIC_CAL_ADC.c
As C is not my strong point, I'm not sure if altered it correctly or not?
Can place the attached PIC_CAL_ADC.c in \Flowcode 7\CAL\PIC directory.
Then if Flowcode is loaded, just hit the Reload icon
Recompile flowchart.
Hopefully will work?
- PIC_CAL_ADC.c
- (118.8 KiB) Downloaded 274 times
- LeighM
Thanks for your work Martin.
Both please use the attached, as I've removed the previous "switch" fix for FVR support,
as Ben has updated all the fcds and ADC component to fix this differently.
So attached should now work in all cases, just select FVR in the ADC component,
Let me know if you have any problems.
Leigh
Leigh
- PIC_CAL_ADC.c
- (118.62 KiB) Downloaded 281 times
Steve001
evening
am I been really stupid here and missing the point ?
cannot get a meaningful result from either test file
a 223.8 mv input shows 1024 or 1.0285.. volts ?
Hi Steve,
You have got Vref+ selected within ADC properties not FVR.
After selecting FVR and recompiling, can you see what happens?
If it still does not work you could use the flowchart I developed for displaying registers.
I must admit im not sure about
Where Vref is being picked up from?
Could be what Leigh mentioned that's changed within FCD & ADC component?
if (Vref != 0) //assign VREF functionality
ADREF = ADREF | Vref;Could be what Leigh mentioned that's changed within FCD & ADC component?
- LeighM
Vref value gets passed into the CAL ADC Enable function...
The value of Vref is explicitly set by the selection of the Flowcode ADC component setting of the "VRef Option" property.
The "VRef Option" is a list of name / value pairs that are read from the target FCD <vref> section.
So the bits to be set in ADREF (in this case) come directly from the FCD.
Hope that helps,
Leigh
void FC_CAL_ADC_Enable (MX_UINT8 Channel, MX_UINT8 Conv_Speed, MX_UINT8 Vref, MX_UINT8 T_Charge)The "VRef Option" is a list of name / value pairs that are read from the target FCD <vref> section.
Hope that helps,
Leigh
Steve001
working now !
helps if you apply updates
http://www.flowcode.co.uk/mmforums/viewt ... 760#p80726
then swap the PIC cal ADC file above
Thank you for everyone's help
223.1 mv input
read as string file in above post 0.2228
read as int file in above post 219
223.1 mv input
jadiflow
- Flowcode v5 User
- Has thanked: 19 times
- Been thanked: 16 times
Not sure how relevant this is, but I had the exact same issue in the past, which was resolved when support send me a new version of the PIC_cal_ADC file. Might be useful that you are using the revised version.
Jan Didden
Jan Didden
