Re: Hello all, NOOB here some comments, thoughts, and questions.
Posted: Wed Nov 21, 2018 11:18 pm
Hi Guys,
Well I have some skin in the game now. I just purchased flow code. Here are some responses:
1) I have not been able to update. I have uninstalled and reinstalled FC to the latest version on your site. I was previously running the 30 day demo.
I think that the demo can't update. My demo expires tomorrow, but I have purchased FC and activated it so maybe the update will work when it reverts to my purchased version. I have allowed FC to connect to the internet through my firewall, I have tried disabling the firewall, same with AV.
firewall: comodo, AV, Avast. Is there a separate update app that I need to allow? I can see it in help but it is grayed out.
2) I will try the ws2811 shortly but Unless it is in the current build on the website I probably don't have the updated component.
3) I did post my FC file. It is posted below. It is just a simple test to read a dmx channel and send it to the oled. I am well versed in DMX physical and electrical connection. I can guarantee that The chip is getting a valid dmx signal. I just can't get a value out of the component. If I am doing something incorrect in my test program please let me know.
4) When I view the coms I see the DMX SLAVE component but the DMX master no longer shows up. This disappeared with the update to 8.1.
5)
I am using the st nucleo 446re board. The bl0061 is using the 446ze (100 pin vs 64 pin). It looks like you are using a 16mhz crystal. I am using the 8mhz from the st-link side. I haven't messed with clocks yet. I am just using the 446 nucleo target you supply. I don't know what it is clocked at. I also have a nucleo f303 to test with.
6) Sorry about the snarky comment.
Leigh: understood. Unfortunately right now I want to make dmx widgets so DMX is on top of my priority list.
You can do DMX on a 8 bit pic. It should be possible on a 180 mhz 32 bit arm.
Thanks, for looking into this for me..
Chad
5)
I don't see this property. I assume it it is an issue with the update problem.You just have to specify the Instruction rate in the new "STARM Instruction Rate" property as there isn't a simple way of getting this currently, my test device BL0061 is 180000000 e.g. 180MHz.
Chad
