timer bug stm32f411VE
Re: timer bug stm32f411VE
Hi LeighM
I have tried various combinations without success.
Pins pb10 and pb11 are for both channel 1 and channel 2.
I have tried both 0x38 and 0x70.
The sda pin always remains high, therefore the clock never starts.
Do you want me to try using other pins besides pb10 and pb11?
- LeighM
- Has thanked: 481 times
- Been thanked: 699 times
Yes, I've fixed it, but haven't yet made it into the office to update the system
I'll dig out the files and attach them here, just a mo ...
Please try these ..
STARM_CAL_I2C.c to go into C:\ProgramData\MatrixTSL\FlowcodeV8\CAL\STARM
32F030R8.fcdx to go into C:\ProgramData\MatrixTSL\FlowcodeV8\FCD\ARM
Please try these ..
- STARM_CAL_I2C.c
- (22.5 KiB) Downloaded 240 times
- 32F030R8.fcdx
- (31.12 KiB) Downloaded 215 times
- LeighM
OK, thanks.
I've just remembered that you are using the RC, so here's an updated FCD for that.
I recently spotted some 'gotcha' small print in the datasheet!
- 32F030RC.fcdx
- (35.51 KiB) Downloaded 207 times
Hi LeighM
If I select channel 2 with any pin the compiler reports this error.
No error however if I select channel 1.
Device STM32F030xC
C~1>arm-none-eabi-gcc -mcpu=cortex-m0 -mthumb -mfloat-abi=soft -D__SOFTFP__ -Os -DSTM32 -DSTM32F0 -DSTM32F030xC -DUSE_HAL_DRIVER -DHSE_VALUE=30000000 -IC:\PROGRA~2\Flowcode\Common\COMPIL~1\starm\batch\..\stm32cubeF0\Drivers\CMSIS\Include -IC:\PROGRA~2\Flowcode\Common\COMPIL~1\starm\batch\..\stm32cubeF0\Drivers\CMSIS\Device\ST\STM32F0xx\Include -IC:\PROGRA~2\Flowcode\Common\COMPIL~1\starm\batch\..\stm32cubeF0\Drivers\STM32F0xx_HAL_Driver\Inc -IC:\PROGRA~2\Flowcode\Common\COMPIL~1\starm\batch\..\stm32cubeF0\Drivers\STM32F0xx_HAL_Driver\Inc\Legacy -IC:\PROGRA~2\Flowcode\Common\COMPIL~1\starm\batch\..\inc -fmessage-length=0 -fdata-sections -ffunction-sections -w -c "Test_i2c_HW.c" -o "Test_i2c_HW_STM32F030xC_30000000\Test_i2c_HW.o"
In file included from C:\ProgramData\MatrixTSL\FlowcodeV8\CAL\includes.c:434:0,
from Test_i2c_HW.c:137:
C:\ProgramData\MatrixTSL\FlowcodeV8\CAL\STARM\STARM_CAL_I2C.c: In function 'FC_CAL_I2C_Transaction_Init_1':
C:\ProgramData\MatrixTSL\FlowcodeV8\CAL\STARM\STARM_CAL_I2C.c:503:42: error: 'RCC_PERIPHCLK_I2C2' undeclared (first use in this function)
PeriphClkInit.PeriphClockSelection = RCC_PERIPHCLK_I2C2;
C:\ProgramData\MatrixTSL\FlowcodeV8\CAL\STARM\STARM_CAL_I2C.c:503:42: note: each undeclared identifier is reported only once for each function it appears in
C:\ProgramData\MatrixTSL\FlowcodeV8\CAL\STARM\STARM_CAL_I2C.c:504:40: error: 'RCC_I2C2CLKSOURCE_HSI' undeclared (first use in this function)
PeriphClkInit.I2c1ClockSelection = RCC_I2C2CLKSOURCE_HSI;
Error(s) in build
C:\Program Files (x86)\Flowcode\Common\Compilers\starm\batch\stm32comp.bat reported error code 1
Device STM32F030xC
Error(s) in build
Thanks LeighMLeighM wrote:OK, thanks, I'll investigate
As you know in Italy there is a complete lock-down.
At this moment I managed to bring home as much material as possible but the board I work on has the pins of the i2c2 on pb10 and pb11.
If you think it would be useful to check the other channels too, let me know that I find a way to solder two pins.
- LeighM
Yes, coronavirus is hitting everything, stay safe
Here's an updated file to try, to go into C:\ProgramData\MatrixTSL\FlowcodeV8\CAL\STARM
- STARM_CAL_I2C.c
- (22.21 KiB) Downloaded 227 times
The errors at the time of compilation have disappeared but unfortunately it does not work.
For double chek I tried to write using the cal i2c software and it worked. ( the same pin )
- LeighM
Thanks for your tests.
I now have channel 2 working
please use attached files
Thanks,
Leigh
Thanks,
Leigh
- STARM_CAL_I2C.c
- (22.25 KiB) Downloaded 226 times
- 32F030RC.fcdx
- (35.51 KiB) Downloaded 176 times
- 32F030R8.fcdx
- (31.26 KiB) Downloaded 183 times
- 32F030Nucleo64.fcdx
- (29.26 KiB) Downloaded 170 times
HI LeighLeighM wrote:Thanks for your tests.
I now have channel 2 working![]()
Thanks,
Leigh
I confirm that I also have the signal.
Only thing is the clock pin scl. If you set 100Khz on flowocode on the oscilloscope, it displays about 500Khz!, If I set 400 Khz the signal goes to over 1 Mhz
- LeighM
Thanks for the info.
Yes, getting the timing correct is tricky, it depends on the clock config settings.
Can you live with that for now in your project?
I will have to have a longer term think about how we get Flowcode to understand the clock settings.
Leigh
Leigh
For sure.
500 khz is more than enough!
in the next few days I will try to program the dsp and check that everything is working properly.
I am checking the sda pin and the transmission seems correct!
I'll update you as soon as I can program the dsp!
edit:
I don't know if you know this st tool, in case it might help
edit:
- en.stsw-stm32126.zip
- (241.57 KiB) Downloaded 178 times
Hi Leigh
I managed to program the DSP!
Furthermore, I did some tests with the i2c timing calculation file and the starm_I2c file.
If I go to assign the value generated through the spreadsheet to MX_I2C_HANDLE_X.Init.Timing I get the correct i2c clock.
For example with my clock to generate 400 Khz I have to set this value 0x00901A53.
How can I assign this value directly via flowcode (for example with a c icon) without having to edit the STARM_I2C_c file?
- LeighM
Ah, well done!
Thanks for the update.
I will have a think on that oneHow can I assign this value directly via flowcode (for example with a c icon) without having to edit the STARM_I2C_c file?
Hi BenjBenj wrote:Hello,
Turning off toggle CS property should help a little bit.
I can see another potential optimisation we could do. I'll have a crack at it for you and see how I get on.
I tried to do what you suggested but the speed didn't improve.
I notice that from the moment of POWER ON to the beginning of the writing on the display almost 2 seconds pass comparable with the time it takes the macro clear.
edit:I checked the compiled c code and the display init macro contains the clear command responsible for the delay.
- LeighM
Making this user configurable is a long term job, so I've updated our version to match your value.For example with my clock to generate 400 Khz I have to set this value 0x00901A53.
This should be available at some point in the auto update system. (Ben is currently doing this when he can get access)
