mLoader and Windows10
RILamb
Been thanked: 4 times
Re: mLoader and Windows10
Post by RILamb »
Steve,
The answer to your question regarding a similar debug message to &pholz, is shown on the first of the attached screenshots. Similar, yes, but not the same. There were 9 debug messages (two duplicated) in total before the final screen (mLoader, brown screen unpopulated, boards not connected). I have only copied the first three screenshots here; I can copy the others across if they are of relevance. Let me know.
Unlike the experience of &Pholz, mLoader_dbg3 does not work successfully on my machine. Happy to go along with your suggestion about creating a new folder. You will have gathered by now that I am well out of my depth with all of this so a suggestion which leads to a 'half-way house' rather than the more direct 'compile to chip' would be perfectly acceptable. Perhaps if you could just elaborate a little on your statement so that I can understand the steps to take to instigate the compile, that would be very welcome.
Thank you. Robert
RILamb
Post by RILamb »
Steve,
Did you get my message of last evening? Couldn't locate on the computer this morning.
Robert
Hi Robert,
Thanks for the mLoader debug messages.
Please disregard my previous post about saving your flowcode program in a different location. The problem is that Flowcode is not finding the correct location of mLoader. I have prepared a batch file which should shed some light on why this is. Please run the attached batch file and let me know the resulting messages.
mLoader_check.zip
(414 Bytes) Downloaded 220 times
Thanks,
Steve.
RILamb
Post by RILamb »
Steve,
This is what came of the 'mLoader_check.zip' test.
Robert
Thanks, Robert.
According to that message, there is no "mLoader" folder under "c:\Program Files (x86)\Flowcode v8\tools". Can you please check that folder to see if it's missing. Perhaps the "mLoader" folder has been renamed or been moved somewhere else?
And where is the location of mLoader that you have been running when launching it directly?
Steve.
RILamb
Post by RILamb »
Steve,
Screenshot of the 'tools' folder. The mLoader highlighted is mLoader_dbg which gave rise to the 9 debug images referred to yesterday.
The mLoader_check is immediately below it. The other various 'mLoader' metamorphisms have been given extensions or deleted.
Robert
I see the problem. The "tools" folder in Flowcode should contain many subfolders such as "Buggyprog", PICkit2" and "mLoader". An image of mine is below.
It looks like your mLoader files have all been placed directly in the "tools" folder, rather than under "tools\mLoader". I don't know how this could have occurred, unless they have been moved by accident.
One way to fix it is to reinstall Flowcode, although a quicker way to correct the problem could be creating an mLoader folder in "tools" and copying the relevant files into it. The second image below should the files that should be in the mLoader folder.
I hope this helps.
Steve.
(48.76 KiB) Downloaded 726 times
(38.78 KiB) Downloaded 726 times
RILamb
Post by RILamb »
Steve,
Sorry for the delay but that little bit of housekeeping took longer than I expected! Our files now mirror one another but I deleted the various versions of mLoader. I downloaded the current mLoader from the website so that puts my system back to square one. I can obviously re-install any of the revised versions as required.
Having now re-run mLoader_check.zip the attached screenshot is what I get.
Thanks for your help and patience.
Robert
RILamb
Post by RILamb »
Steve,
Continuing on from the last posting I have now replaced the 'original' mLoader with the 'mLoaderA' version and that works perfectly just as it did for the other chap yesterday. Flowcode8 program runs and combi board does what it should do! The failing seems to have been with my file structure not having a separate folder for mLoader. Bad housekeeping; more probably ignorance on my part. Anyway, the end result is a success down wholly to your effort and perseverance. Thanks very much for the time and effort you have given over to this just sorry for the confusion caused by my mistake.
Robert
Hi Robert,
Excellent - I'm glad you're back up and running. And thanks for your patience and help in sorting this out.
Steve.
I have created a new version of mLoader which will be distributed as part of a Flowcode v8 patch that I hope to release in the next week or two.
If anyone wants to try it (especially @PHolz, @RILamb, or anyone else experiencing the problem in this thread), you can download and unzip the attached and replace the mLoader.exe file in the Flowcode v8 "tools/mLoader" folder.
If you do try it, please let me know if it works ok.
Steve.
mLoader.zip
(3.57 MiB) Downloaded 242 times
