Access Violation reading from flash drive
daveb0360
Has thanked: 35 times
Been thanked: 12 times
Re: Access Violation reading from flash drive
Post by daveb0360 »
Hi Ben,
So what you're saying then, is that there is no need to use the pk2cmd_mtx.exe file from your website any more? (although I am using this....and it works!) and that the PPPV3 entry can be used to determine and/or set bit parameters even if that programmer is not specifically used?
Another post in the forum, for example, gives totally differing settings. Suggesting that the 'use external app......' tick box should be un-ticked...........it's confusing to us users you know!
Suggestion - wouldn't it be more economical for you guys, to include this info in the product help files rather than re-visit it over and over in the forums? Also, wouldn't it be wise to append to or remove posts relating to these/outdated issues when they are no longer valid - for example, when it is no longer current/applicable to a new release. People wouldn't be asking these sorts of questions if there was definitive and up-to-date info available and that that info was simple to find.
Dave
