Ok thanks for the reminder. I have managed to make this change to the component. Are any of you able to test the code for me before I put it into the Flowcode PIC release.
To start copy the attached file into your "Flowcode v4/Components" directory.
Then use the CAN2 component and the custom code feature go into the defines section of code for the CAN2 component and change this line.
#define INTERNAL_CAN_ENABLE 0Code: Select all
#define INTERNAL_CAN_ENABLE 1
