I also thought these devices were not yet supported for programming but I could be wrong. If you can get a flashing LED program in then you should be able to get larger more complex programs in too. I will have a dig in and see where we are with this family of devices.
wifi E-Block and accelerometer E-Block
Re: wifi E-Block and accelerometer E-Block
- Has thanked: 3 times
- Been thanked: 41 times
no erase on 18f26k22
I was able to program but not to erase on EB006 and HP488
With PPP->File/Erase pic micro ->Erase failed
Is there a way to erase with EB006?
I saw that:
http://www.microchip.com/forums/tm.aspx ... print=true
I tried to disconect VDD pin but no success.
I saw that:
Ah ok it is as I thought, the K22 devices are not currently supported by the EB006. We are working on this but i'm afraid I cannot offer an immediate solution.
ppp for 18f26k22
I can now erase the 18f26k22.
The erase method for k22 devices is the "18F_ERASE_14xx20" method
You just need to change:
It should work with other k22 devices.
I can't upload my new working PPP to the forum.
witherase=18F_ERASE
in the "ppp_config_data3.cfg" file, in the 18F26k22 area.erase=18F_ERASE_14xx20
The 18f26k22 is now fully working: programming and erase (see previous post)
But the 18f46k22 can't be programmed.
PPP displays the following message:
Programming failed: <1><2><3><5><6><8><9><10><11><12><13>
Can you help?
Can you help?
The K22 devices are not currently supported using PPP we are looking into this. For now you should be able to reprogram them by using a PICkit and the PICkit header on the board.
Then I will use the 18F26k22 with my working PPP version on it.
I am waiting for your next PPP version.
I performed tests today with GPS on UART1 and Wifi on UART2 on 18F26K22.
I can receive successfully the data from the gps on a wifi computer.
