Yes I have this wire connected. You are supposed to connect this wire to most boards the exception is LED board)tulipman wrote: 1) do YOU have to do the same on your board (i.e. connecting a wire between EB006 and EB005)?? !!!
It does state that in the instructions and
Does not matter, these things can be easily misread. I know I have misread on occasionsmedelec35 wrote:If not then either you have not got +5V going into +V terminal block of LCD Board
At least your up and running that's all that matters
There is no hardware problem all working as it should be. I only suggested there could be a hardware problem because you still not got LCD to work and I did not know you had not connected supply wire to LCD, and I had run out of ideas what it could be.tulipman wrote: 2) WHERE do you think is the [hardware] problem?? On the LCB board or on the EB006???
Thanks for letting us know anyway.
